paxton novi1200 questions
AbodyJohn88
do you guys see a problom with runnin 9.2-1 compression with iron heads with no intercooler, but meth injection on 93 pump gas and running it up to 15-20 psi??? kepp in mind this is mainly a street car. looking to make around 600whp with a paxton novi1200.... also with the novi1200 kit its comes with a box that encloses the whole carburator and pressurizes it, do i still need a blow thru carb??
oh yea, 410 inch smblock, forged assembaly, stage 3 ported x heads, hyd roller .575 lift, eddy victor intake, tti step headers.
yeah i do, my dads 540 needed 8 to 1 compression and a intercoller to runn 16 pounds of boost, and he has indy 440 sr-1 heads i think, i know their indy and have 440 in the name, but i would forgo the extra cash and get a blow thru carb, we found that it makes tuning a little bit easier
IMHO On a 410 small block you probably wont need that much boost to reach those horsepower figures, And 20 psi is a whole lot for a serp belt if thats what your running, Iron heads and no intercooler is just asking for problems at that kind of boost. I have used meth injection and an intercooler but not just meth injection. I worked at a place that we put a small powerdyne unit on a Lexus IS 300 with a bone stock 3.0L motor 9.5:1 compression and it made 370 something at the ground at 14 psi slipping the serp belt no intercooler no meth injection with AFR's in the 12.5 range. You should do it no problem if you can move enough air :happy3:
Guys do it all the time. You may consider a Multi Nozzle Meth System though with no intercooler. Check out............. http://www.alcoholinjectionsystems.com/index.html
My Compression is 9:1 and I will be trying my tune at 15lbs of boost on a TT 410 CI SBM. RHS/Indy Iron Heads, Solid Flat Tappet Cam .634/.634 Lift, 241@50.... Twin Water/Air Intercoolers a Heat Exchanger with 2 10" Fans and Meth Injection. Direct Port Sequential EFI. I hope to make 800 +rwhp.
At 5-7 lbs of boost you should hit 600whp easily. You want to keep keep the intake charge as cool as possible. 15lbs you should be in the 800++rwhp range. But at that amount of boost you will definatly generate alot of heat with the Paxton, I know that.
What head gaskets are you using? Are the heads Studded?
You figure your engine NA should make right at 500HP or so. 1 Bar "14.7PSI" should theoretically DOUBLE the HP. So you are talking 1000HP at the Crank.
With the enclosure you should not need to get a Blow Thru Carb.
Guys run 10:1 using Meth....... Its all about keeping the intake charge cool.
You can research here.............
i think 9.2 to 1 is way to high for boost especially 15- 20 pounds
There is a guy on the turbo forums that is running a big block with a turbo. He is running 9.3:1 compression with a home made (?) meth injection on pump gas with 15 pounds of boost. In one of his messages he sent me he said that running he used to run lower (7.7 or so) compression and the car runs much better now with the higher compression. If I remember right he is making in excess of 1400 hp and is running way into the 8's with a 3600 pound Dart.....This http://www.telusplanet.net/public/mblasco/Car/ is the page with his pictures on it.......
Louis, that is the company you got yours from, correct??
Not yet, it's next on the list and the last big purchase to complete everything. I talked to the vendor a few months back and I will call to place the order at that time. 1 nozzle will be on each turbo at the air inlet and the 3rd one will be about 6" before the Throttle Body.
Spraying into the compressor inlet or outlet?
Im not saying it does not work because it does, I have seen some draw through carb set ups that have extremely eroded compressor wheels from running the fuel through them. For a toy its fine but keep in mind how much you payed for those turbo's.
The Inlet......... See here for an explanation.
Positioning The Water Injection Nozzle
One of the most common questions we receive from customers is "Where is the best place to install my water injection nozzle ?". Unfortunately, the answer to this question is often times different for everyone as it depends on the application. There are many factors such as type engine, supercharger or turbocharger, EFI or carbureted, intercooled or non-intercooled and so forth. In this section will go over the various locations in which you can mount your water injection nozzle or nozzles. As well as locations in which you do not want to install your nozzles and explaining the reasons for both. Are you ready? Lets begin.
EFI/Carbureted Turbocharged & Centrifugal Applications
Due to their similarities in system design and layout, we have combined both turbocharger and centrifugal superchargers applications in one category as the nozzle locations are the same for both applications.
1. Pre-Turbocharger/Centrifugal Injection
By placing the water methanol injection nozzle or nozzles pre-turbocharger or centrifugal supercharger and injecting a fine precise amount of water methanol into the air inlet of the compressor can have a dramatic positive effect on compressor efficiency (particularly with turbocharger systems and high boost centrifugal applications) while substantially lowering discharge temperatures at the source of compression. On 8-25 psi applications, users can expect to see a 70-160+ degree drop in compressor discharge temperatures. While reductions of 160-240+degree's can be had on 25-60+ psi high boost applications such as diesels.
How is this possible?
When water methanol is first injected, we're able to begin slightly cooling the incoming air entering the compressor. This air is already relatively cool in relation to the ambient temperature of the day as it has yet to be compressed and heated. Depending on the temperature of the day and how the air inlet is plumped and where the air is being drawn in from, the incoming air entering into the inlet of the compressor commonly ranges between 5-20 degree's above ambient. Only minor cooling of the air charge occurs at this stage before it enters into the compressor. More importantly, we are about to dramatically cool the air that is being compressed and heated within the turbocharger.
It's important to understand it is here that the heat is being generated.
A turbochargers impeller can spin at an astonishing speed between 100,000- 150,000 rpms. While centrifugal supercharger impellers spin between 40,000-65,000+ rpm. Between each pair of blades on an impeller exists a wedge shaped open space which the air fills in. As the impeller is spinning, this wedge shaped air pocket is subjected to tremendous centrifugal forces and is forced outward away from the center of the impeller to the outer edges. It is here where the air begins to stack up and compress against the compressor housing forming the heat as it makes it way into the scroll.
As the compressed air heats up, it tries to further expand, making it now more difficult for the heated compressed air to pass through and exit the compressor thereby lowering the compressor efficiency. In addition, this compressed air is taking up more space within the compressor limiting new incoming air from being processed. Furthermore, the hot compressed air exiting the turbocharger is less dense as it has been heated significantly. Therefore, containing less power producing oxygen while making the engine considerably more prone to detonation.
By cooling the air as it's being compressed within the turbocharger or centrifugal supercharger, the compressed air is now substantially cooler, more dense, taking less space and moves more efficiently through the compressor allowing us to pack and process more air through the turbocharger or centrifugal supercharger. This leads us to our second benefit. Improved compressor efficiency.
All of this results in improved compressor efficiency. Because of this improved efficiency the compressor does not have to work as hard to produce the same amount of boost as without the water methanol injection. In turn it raises the maximum mass air flow of the compressor. Thereby, making a smaller turbocharger or centrifugal supercharger now perform like a larger turbocharger or centrifugal supercharger with the addition of the water methanol injection.
Lastly, as already mentioned above, pre-compressor injection substantially lowers the discharge temperatures exiting the compressor. The engine is now less prone to detonation through this reduction in air charge temperatures. Furthermore, the use of an intercooler is dramatically reduced and in some applications no longer needed as it may not offer substantial further cooling effects in return for the pressure drop caused by it. Removal of the intercooler could now offer a further increase in boost pressure at the engine as well as compressor efficiency.
While all of this sounds very exciting. To do this properly requires proper sizing of the nozzles in relation to the compressor size and output. Additionally, the type fluid being used also effects the size of the water injection nozzle selected. When done properly, very little of the water methanol mist injected into the inlet of the compressor survives the process. Thereby, discharging a much cooler air charge with a relativity high humidity with very little or no water methanol droplets present.
When injecting water, we can quickly over saturate the air charge and have an excess of fluid discharging the compressor. Water has a much higher latent heat of vaporization, nearly double that of methanol, and does not flash (instantly evaporate) like that of methanol or other alcohols when injected into a hot air stream. Therefore, a smaller nozzle must be used when spraying pure water.
A better choice for pre-compressor injection is a greater concentration of methanol vs. water or pure methanol. Methanol instantly flashes (evaporating) as soon as it enters into a hot compressor and meets the heat within it. By using an alcohol, this dramatically reduces the amount of actual fluid exiting the compressor due to it‘s fast evaporation. Additionally, methanol offers much greater cooling effect then water. Furthermore, methanol is also less dense then water thereby having a softer impact on the impeller. The specific gravity of pure methanol is .792 @ 68° F compared to water which is 1.00 @ 64° F.
One major concern associated with pre-compressor injection is erosion of the impeller. This is only likely to occur when injecting solid stream of water at the impeller of a turbocharger or using an excessively large nozzle. Impeller erosion is highly unlikely with centrifugal supercharger as they spin at a considerably slower speed then turbochargers. Impeller erosion is of little concern with centrifugal superchargers.
2. Pre-Intercooler Injection
While pre-intercooler injection may at first seem like a logical approach. Thereby, combining the effects of water methanol injection within the air-to-air intercooler for an increased synergistic effect. It is not so. Matter of fact, it's the opposite. The cooling effects and benefits offered by the water methanol injection are less when injected here then in all other locations. Further, more other issues arise such as puddling which can form in the bottom of the intercooler. Additionally, pour atomization will occur as the fluid will accumulate in the individual air to air intercooler core walls of the intercooler forming larger droplets which will eventually break away resulting in pour atomization. We do not recommend pre-intercooler injection.
3. Post Intercooler Injection
Post intercooler injection technically refers to injection anywhere after the intercooler. However, in this discussion we are specifically taking about post intercooler injection which takes place directly after the air-to-air intercooler on an application which has a considerably lengthy discharge tubes as shown in the picture above.
Here the user has numerous locations and plenty of space available to inject after the intercooler. Often times users will believe by placing the nozzle further away from the intake of the engine, they will have better atomization, better charge cooling and ultimately better performance. In a case like the engine above, placing the nozzles directly after the intercoolers is not as desirable as placing them directly inches away front of the throttle body or carburetor, as this is excessively further away then needed.
While this will result in a well atomized, cool air charge entering into the intake manifold. Much of the water methanol injection would have already evaporated leaving little injection available for internal cylinder cooling, added detonation control and reduced EGT's. Additionally, In some case's the air charge can actually begin to heat back up due to excessively long discharge pipes being routed around hot radiator, turbocharger, hot pipes and exhaust.
Location of the mass air meter and IAT or ACT sensor location should always be considered. Never inject pre-mass air. Only in pre-turbocharger applications when done properly can one inject prior to the mass air.
4. Pre Throttle Body/Carburetor Injection
Positioning the water methanol injection nozzles or nozzles just before the throttle body or carburetor on turbocharged and centrifugal supercharger applications is by far the most common position and one of the most beneficial of all. Furthermore, most every application can easily be fitted in this manor. With injection taking place just before the throttle body/carburetor, inches before the intake of the engine, significant cylinder cooling and detonation suppression is achieved. Additionally, air charge temperatures are significantly reduced through the intake manifold.
Care should always be taken concerning adequate distribution. In many cases intake manifolds can have individual intake ports beginning right after the throttle body. In applications such as this, the nozzle need only be pulled back away from the throttle body 4-5 inches to ensure proper distribution between all intake ports and not feeding one more then others.
Many of our concerns are eliminated when injecting in this location such as injecting prior to the mass air meter, intercooler or being excessively to far away from the intake of the engine. With injection taking place right before the intake of the engine, the effects are maximized.
As already mentioned, positioning the water methanol injection nozzles or nozzles just before the throttle body or carburetor on turbocharged and centrifugal supercharger applications is by far the most common position and one of the most beneficial of all as it offer excellent air charge cooling and exceptionable detonation control and cylinder cooling.
5. Post Throttle Body/Carburetor Injection
In some applications the need for injection after the throttle body or carburetor is necessary. This may be due to lack of other locations that are available. For instance with carbureted applications where users do not easily have the ability to spray before the carburetor, they may slip a carburetor plate under the carburetor and drill and tap it for the nozzles.
When doing so it's absolutely imperative that the use of a check valve or solenoid is used to prevent siphoning during times when the engine is not in boost and under a vacuum. Unlike other competitors kits which do not include a one-way check valve or solenoid and charge additionally for it. We offer one-way check valves standard with every system as an integrated solution rather than just an after-thought.
As always and more so then ever, care must be taken to ensure proper distribution between all intake ports. Locating the nozzles after the throttle body or carburetor greatly raises the concern for proper distribution of the water methanol injection as injection is taking place right in the intake manifold plenum. Users must evaluate their intake manifold design and nozzle or nozzles location and determine if proper distribution will be maintained before injecting.
Post throttle body/carburetor injection should only be considered when other more preferable locations are nor available.
6. Direct Port Injection
Direct port injection involves positioning a water/methanol injection nozzle in each intake port of the manifold. This allows for the use of several smaller injectors to be used in each intake port as opposed to one larger nozzle located upstream of the intake manifold servicing all the cylinders. Unfortunately, direct port injection generally requires the removal of the intake manifold to complete installation. Thus making for a considerably longer and more complex installation.
While this does offer the benefit of better atomization, more uniform and even distribution through out the cylinders. In addition to possibly better detonation control, cylinder cooling and reduced EGT's. It's generally not needed as other nozzle locations can be nearly just as effective requiring considerably less work and costs involved. Furthermore, one problem with running direct port injection is users are not likely to monitor differences in IAT's (intake air temperatures)
Port injection is more common on 4 cylinder engines as added cost's for additional nozzles and fittings is acceptable and removal of these type of intake manifold is generally much easier. In general, we do not recommend port injection as we have achieved excellent results using other less complicated and costly nozzle arrangements and locations.
7. Staggered Injection
Staggered injection involves combining pre-compressor injection with an additional secondary nozzle positioned further down the turbocharger or centrifugal supercharger, such as pre-throttle body/carburetor injection. By combining pre-compressor injection with pre-throttle body injection, were able to improve the efficiency of the compressor while dramatically reducing air charge temperatures at the compressor and again at the intake for a combined synergistic effect. Furthermore, the secondary nozzle provides the necessary cylinder cooling, detonation control, and reduced EGT's which the pre-turbocharger nozzles does not.
Best of all, installation remains essentially the same and costs are only marginally more as the addition of a secondary nozzle and tee fitting are all that is required. We highly recommend the staggered injection for all turbocharged applications and high boost centrifugal applications.
For complete details on Pre-compressor injection and Pre-Throttle Body/Carburetor injection these are listed above individually.
Pre-Compressor Injection Precautions
Never place your water methanol injector before the mass air meter. The only time this may be allowed is with pre-compressor injection. When done properly, little or no fluid is exiting the compressor. Only a cooler denser, high humidity air charge with little or no actual fluid remaining in the air charge after the compressor.
When installing your water methanol injection system on a EFI vehicle, it's best to first determine where the IAT or ACT sensor is located before deciding on a nozzle locations. Often times we can position the nozzle before the factory IAT (intake air temperature) or ACT (air charge temperature) sensor location without having to relocate it. This allows us the ability to better use the IAT or ACT sensor for retuning the ECU for the addition of the water methanol injection system.
Unfortunately, many of our newer vehicles have now incorporated the IAT sensor in to the mass air meter. With most applications we can disable this IAT sensor in the mass air meter and install a new separate IAT sensor in a new desirable location.
Positive Displacement Applications
1. Pre-Throttle Body/Carburetor Injection
On EFI/carbureted positive displacement applications, pre-throttle body/carburetor water methanol injection evolves positioning the nozzle or nozzles just before the throttle body or carburetor. This is by far the most common location for EFI positive displacement applications. While carburetor applications commonly injected under the carburetor. See post-carburetor injection below for details.
A common question that often comes up from customers, "Is it safe to inject into the inlet of my supercharger?". Absolutely. In fact, by injecting a water methanol mixture into the inlet of your positive displacement roots or screw style supercharger, not only can we lower discharge air temperatures, we can also lower internal supercharger temperatures and improve supercharger efficiency. The water methanol injection works to help seal the tight clearances between the rotors and the housing improving supercharger efficiency. As many times the supercharger are operating in dry conditions such as EFI applications which have the injectors placed after the supercharger. This is one advantage of having a carburetor mounted above the roots or screw style supercharger as the gasoline has a similar effect.
Another advantage to pre-throttle body/carburetor injection is there is no need for running multiple smaller nozzles to increase atomization on larger output engines. Since the fluid has to physically pass through the superchargers rotors, a single larger nozzle will work just as well as two smaller nozzles compressing of the same output as the one larger nozzle. The result is the same coming out the bottom of the supercharger.
2. Post-Throttle Body/Carburetor Injection
On EFI/carbureted positive displacement applications, post-throttle body/carburetor water methanol injection evolves positioning the nozzle or nozzles just after or beneath the throttle body or carburetor. This may be due to lack of other locations that are available. For instance with carbureted applications where users do not easily have the ability to spray before the carburetor, they may slip a carburetor plate under the carburetor and drill and tap it for the nozzles.
When doing so it's absolutely imperative that the use of a check valve or solenoid is used to prevent siphoning during times when the engine is not in boost and under a vacuum. Unlike other competitor's kits, which do not include a one-way check valve or solenoid and charge additionally for it, we offer one-way check valves standard with every system as an integrated solution rather than just an after-thought.
3. Direct Port Injection
Direct port injection involves positioning a water/methanol injection nozzle in each intake port of the lower manifold. This allows for the use of several smaller injectors to be used in each intake port as opposed to one or two larger nozzles located before the supercharger servicing all the cylinders. Unfortunately, direct port injection generally requires the removal of the intake manifold to complete installation. Thus making for a considerably longer and more complex installation. Additionally, by injecting after the supercharger we are not able to cool down the rotors and improve the superchargers efficiency as we can with pre-throttle body/carburetor injection.
While this does offer the benefit of better atomization, more uniform and even distribution through out the cylinders. In addition to possibly better detonation control, cylinder cooling and reduced EGT's. It's generally not needed as other nozzle locations can be nearly just as beneficial requiring considerably less work and costs involved. Furthermore, one problem with running direct port injection is users are not likely to monitor differences in IAT's (intake air temperatures)
Have questions about our products or need help choosing the right water methanol injection system for your application. Call us at 1-801-447-2559.
wow, yea it seems that i could run just 10-12 pounds of boost and be past the 600whp i want, thats all i really want to make because of the stock block. thanks everybody for the knoweldge!!
Actually, your right, to a degree, if you just simplly add boost without much reguard for anything else. The problem with new guys or dumb kids is the reguard of for what there doing, lack of research or a good mentor/book.
Also, this will boil down to application, tolorance of the system you will use or need to use, etc....
It's the same song as allways sung, it's a package/system that has to be right for you and your application. If your OK with runing race fuel, meth fuel and well, you know the drill.
Streetable is a very flexable word to throw around. :toothy7:
yeah all the lacking knowledge that i know is from watching the buildup of my dads power wagons engine, its a 1968 dodge power wagon with a blown 540 ci, wedge. it makes 1205 on pump gas and over 1300 with race gas (tuning required though) and the engine builder told us that we couldnt go higher than 9.0 to 1 compression with the kind of boost we were running, so that made me think you couldnt run forced induction above 5-6 pounds with a compression of 9.0 to one, that what i may be doing with my dart unless i swap in the 2jz or a slant six, then im going crazy with the forced induction, especially with the 2jz i will
i decided to bite the bullet and will be running an air/water intercoller hidden behind the front passanger wheel up inside the fender. and i will still run the meth injection. thank you everyone for your opinions and im sure i will be asking more questions as the build comes along.
I know its obvious but your going to need a rising rate fuel pressure regulator.
And what kind of head gaskets are you guys using for boosted small blocks?
I used ARP Head Studs & Cometic Gaskets sprayed with Copper Coating on mine. It should hold the boost up to 25 PSI or until the cylinder sleeve's wanna come out of the block! haaaa
I run 10psi on my Viper (think 360engine with W6 heads plus 25% extra cylinders). My 9-1 FORGED racing pistons, cam, headers, ported heads, custom intake, larger TBs, etc etc, makes 720rwhp with water/methanol injection. It also makes over 800rwtq soon after 2,000rpm. This is a Kenny Bell TS blower done by Roe Racing. No intercooler.
My Paxton Novi 2000 at stock 7psi with intercooler (required) runs water/meth on a stock 10-1 hyperutectic piston engine. It makes only 580rwhp. and only makes good power after 4500rpm. However, when you turn on the twin fogger Nitrous System the torque goes up to 750rwtq and the hp goes to 802rwhp/930bhp.
Expect that the 720+ rwhp of the Twin Screw blower makes power all the time whereas the Paxton Centrifigal blower only starts adding power after 3500rpms. The Paxton type blower uses a Turbo style compressor and requires an intercooler system because of the extremely high rpms of the impeller. Even stock 7psi system comes with an intercooler. It is inadequate if it's a hot day or you run the car hard it will heat up and lose power - unless it detonates and destroys your engine.
What is important is the PISTONS more than the compression. The upper ring land needs to be thicker on a blower piston or the detonation will break the ring land causing piston failure. Your connecting rods are hp limited as well. Although Dodge uses good MS connecting rods, I wouldn't go much past 600rwhp with stock rods and there's no guarantee that you won't overpower the rods at that level. A Viper engine is built for high power and it has 2 extra rods to carry the hp to the crankshaft. Viper engines can go to about 800rwhp and then H beam rods are needed. 1,000rwhp means that a billet maincaps are needed.
Hope that helps.
