Poor quality parts ruining the hobby for me
General Discussion
  1. KindredSpirit
    KindredSpirit FABO Gold Member FABO Gold Member
    80
    33
    Sep 1, 2015
    Petaluma, CA
    Local Time:
    7:13 PM
    Agree on OER as a new radiator was supposed to be an exact replacement but had mounting holes drilled in the wrong spots and no brackets on the side to hold overflow hose and shroud. But OER is not alone. I'm on my third attempt at a brake distribution valve after two bad ones from Inline Tube and a second master cylinder after the first bad unit from Rock Auto. And, I haven't even put the car back on the road yet - these parts were so bad they leaked or failed after installation. Yes gentlemen, I also followed every tip on this forum about installation. Just ridiculous.
    • Agree Agree x 1
    • greymouser7
      greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
      3,182
      2520
      Apr 17, 2010
      78002 down the road from Atascosa, Texas
      Local Time:
      9:13 PM
      Ballast resistors, ECU's, voltage regulators, alternators, starters -all parts that fail much more often than they used to. PLUS you cannot get some of these parts at parts stores anymore- they have to order it, which is just as fast if i order it through rockauto or ebay
      as for alternators and starters -for my other used cars, they are good for 2 years, maybe a little more on the salt coast of corrosion. We replace ground wires out here, and often in florida near beaches.
    • 68383GTS
      68383GTS Well-Known Member
      7,331
      835
      Nov 15, 2007
      East Peoria,IL
      Local Time:
      9:13 PM
      This is why need need a Parts Supplier feedback forum....
      • Agree Agree x 1
      • Bulldozer
        Bulldozer Well-Known Member
        15,382
        2004
        Oct 16, 2011
        why
        Local Time:
        9:13 PM
        I'm on my 3 rd master cylinder , the first two , " brand new" , not reman, not worth a shit.
        hopefully 3's a charm , because brake fluid isn't exactly cheap
      • Takoctopus
        Takoctopus Well-Known Member
        70
        32
        Dec 30, 2016
        Avon Indiana
        Local Time:
        12:13 PM
        My new master cyclinder leaked from a bolt on the bottom, so I fixed it instead of ordering another that might leak also.
      • JBurch
        JBurch Well-Known Member
        1,797
        919
        Oct 17, 2009
        Owego, NY
        Local Time:
        10:13 PM
        How much of the problem do you think is "Counterfeit parts"?? Was a problem decades ago, companies tried to police the problem, just too much money to be made for it to stop, AND lack of prosecution if they; the counterfeiters; are caught.............
      • barbee6043
        barbee6043 barbee 6043 FABO Gold Member
        11,560
        4272
        Jul 20, 2008
        Shepherd, Texas ( SE Tx)
        Local Time:
        9:13 PM
        My '95 Ram 3500 Cummins I bought new, it was made in Mexico, the front wheel bearings fell apart at 100,000 mi which I was told was "normal" for those models and years! It had ate a spindle too, all this was replaced at 2005, has 220,000 mi now, and still going. I have no idea what was the maker of the second set of bearing, I will just drive it till it goes..
        I say, parts bought now days at auto parts store is a crap shoot, and buying a certain brand does not guarantee success!!! I have done sets of brakes ( 9 and 10 in.) in last 3 years and no problem, but lucky, VR another story!
      • pishta
        pishta I know I'm right....
        16,187
        5911
        Oct 13, 2004
        Tustin, CA
        Local Time:
        7:13 PM
        Would an Edelbrock water pump last 100,000 miles? No, yet they are MORE $$ than OEM. That goes for alot of our parts. After market is not always better. You buy a reman alternator when your $3 brushes and $2 bearings go out? Open it up and change them! MC, same thing, just get some seals. You wouldnt buy a new motor if the bearings went out would you? My 65 FSM shows you how to take apart a power brake booster! But try finding parts for that.....It is what you make of it.
        • Agree Agree x 1
        • Bulldozer
          15,382
          2004
          Oct 16, 2011
          why
          Local Time:
          9:13 PM
          the first m/c I took apart and no amount of seal would seal up the shoddy finish in the bore. after 24 OZ. of fluid through the second one , the air never went away , finally the 3rd one , and yes the CHEAPEST one in stock , bled solid after the first 5 strokes of the pedal.
        • pishta
          16,187
          5911
          Oct 13, 2004
          Tustin, CA
          Local Time:
          7:13 PM
          Exactly! Would your old one clean up with a $8 hone job and $5 pistons? you could probably produce a better finish with that drill mounted hone than the aftermarket one. And you would be the final inspector......
          • Like Like x 1
          • moparownr
            moparownr FABO Gold Member FABO Gold Member
            69
            19
            Dec 28, 2015
            Nacogdoches, Tx
            Local Time:
            9:13 PM
            Our old cars are here to put parts on, because they were made when America was the number ! manufacturer, unfortunately now everything is made outside the US and quality is a foreign word....
            • Like Like x 1
            • threewood
              threewood Well-Known Member
              388
              214
              Nov 11, 2014
              Yuma
              Local Time:
              8:13 PM
              Good quality parts use to be run of the mill at regular price. Now you have to pay out the ass if you want something that will last over a year. It's ridiculous when a 100k mile used part is more suited to last than a brand spanking new one. And Mopar repop parts are not cheap, even for the Chinese garbage that is on the market. I had a $300 repop dash for my 62 (tiny little eyebrow) peel back after ONE DAY! I've even had made in the U.S.A. parts like Holley fuel pumps leak like a sieve right out of the box. Gauges fail after one days use. It goes on and on.
            • pishta
              16,187
              5911
              Oct 13, 2004
              Tustin, CA
              Local Time:
              7:13 PM
              "Pump doesnt work
              Bought pump installed on car would draw fuel from tank so gravity prime lind and pump just pouring fuel out of bottom. Was against a time line so had to go pick up and over pay for new holly to get on road"
              "Immediately Leaked
              I bought this hoping to save a few dollars. Got it installed and plumbed, put fuel in the tank, and immediately noticed it was leaking from the pump body. I checked all my connections and everything was good. I removed the pump and took it apart, and found THEY FORGOT THE GASKET during assembly. The casting was also terrible and could have leaked even with the gasket. I RTV'd it up and tried to make it work, but when i put voltage to it, it seemed intermitant and still leaked.
              So... I went and bought one that was MADE IN USA, that worked the first time, and was easier to install." Good for you for finding one that didnt leak.
            • yellow rose
              yellow rose Doctor of Thinkology.
              19,997
              16096
              Jun 19, 2015
              Living on the razors edge
              Local Time:
              7:13 PM
              I switched to MFI in 1988 because I was sick of dealing with fuel pumps by Holley. They were kink back then. I finally fixed them by using high quality brushes in them and had an engineer friend develop a bypass system to keep the pump from loading up and heating the motor and melting the brushes. Even the best brushes I could find.
              • Like Like x 1
              • QuickDart360
                QuickDart360 Well-Known Member
                1,028
                340
                Apr 5, 2014
                San Antonio
                Local Time:
                9:13 PM
                I bought a napa ignition switch for my dart sport. From day one as I turned the key it felt rough. I thought it's new need to use it to let it "smooth out". Yeah right. Half a year went by and still rough. Also sometimes it would start sometimes not. Eventually it smoked and took a dump! Not even a year gone by. So went to several auto stores guess what all made in taiwan. Napa one happened to have box taiwan! So frustrated went on ebay found one by standard ignition. Said made here in the states. 2 or 3 years later she is smooth and no drama. Also came across some nos mopar ignition switches but were a little pricier.
              • barbee6043
                11,560
                4272
                Jul 20, 2008
                Local Time:
                9:13 PM
                The Summit manual water temp gauges works ever now and then, ( mostly then) It was cheap so what do I really expect!?????
              • Bulldozer
                15,382
                2004
                Oct 16, 2011
                why
                Local Time:
                9:13 PM
                haha ! I'm on my second one of them too lol
              • threewood
                388
                214
                Nov 11, 2014
                Yuma
                Local Time:
                8:13 PM
                Haha! I forgot I bought one of those piles of crap as well. Worked fine for 30 minutes then stopped working fine. It was dead but every once in a while it would come to life. Threw it and the mech oil pressure gauge in the trash and replaced with electric Autometer gauges and no more problems.
              • threewood
                388
                214
                Nov 11, 2014
                Yuma
                Local Time:
                8:13 PM
                The issue with mine was a crooked gasket, gas was pouring out. Took it apart and reset the gasket and no more issues. If it would have caught a spark the car would have burned and i would have broke it off in Holleys a$$. I'm done with their products, their regulators suck too.
                • Like Like x 1
                • Charrlie_S
                  Charrlie_S Well-Known Member
                  2,763
                  649
                  Oct 17, 2005
                  Silver Springs, FL
                  Local Time:
                  10:13 PM
                  Bought a Raybestos brand bearing and hub assy, for premium dollars. It had to be ordered. When it arrived, it was the exact same thing, even the paper work in the box, as the cheap parts store brand. I called Raybestos to complain, about paying premium price for the same part that I could get for about half. They told me, they don't make the bearing/hub. They just license the name, to someone else.
                • cosgig
                  cosgig MoBro Inc. FABO Gold Member
                  11,168
                  4093
                  Jul 20, 2008
                  Pinckney, Michigan
                  Local Time:
                  9:13 PM
                  Try buying Harley replacement parts from the dealership....black oil filter, $15......want the chrome one? $40
                • famous bob
                  famous bob mopar misfit FABO Gold Member
                  14,921
                  5234
                  Aug 14, 2011
                  okla
                  Local Time:
                  9:13 PM
                  Only really bad part I`ve run into was a ford relay from o`reillies. Lasted about 1 yr or so, found the Chrysler relay that was in the basket when I got my basket case 68 fastback. Installed it and hooked the n/starter switch up, all is good now !
                • enigma57
                  enigma57 Well-Known Member
                  312
                  279
                  Apr 8, 2012
                  Texas
                  Local Time:
                  9:13 PM
                  Oh boy! Now I'm a bit worried. Bought a new Carter brand electric fuel pump last month. Sure hope it works and no leaks. We'll see.
                  Best regards,
                  Harry
                • pishta
                  16,187
                  5911
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  7:13 PM
                  your buying the warranty only. Same part, but lifetime warranty....happens all the time. Get the 90 day for half price.
                • pishta
                  16,187
                  5911
                  Oct 13, 2004
                  Tustin, CA
                  Local Time:
                  7:13 PM
                  not a prob with Carter. Although anything can be defective. 4% of electronics were bad OOTB when I worked at Circuit City. We saw far less because we didnt take back half the stuff as the factory would handle it through its channels. Try returning a refer to CC. Some of the bottom shelf shit like Broksonic VCR's were so cheap that we didnt even repair them. Put it in the crusher and give them a new one...."Non RTV (return to vendor) field destroy..." They were a simple transport built on 1 PCB and a power supply, all the least expensive crap the manufacturer could source. weighed about 2 lbs.
