Post your 12 second small block combos
Specs on the engine? heads, cam, compression?
Thanks guys engine is a stock bore 1969 318 factory forged crank, rods and forged Ross pistons zero decked .508 cam 292 speedmaster airgap intake with 700 dbl pump holley has 1 5/8 hookers with a 4500 501 converter 904 trans and a 3.21 rear running through flowmaster super 50's muffs.converter is set up for 4.10 gear. we have 1.6 ratio rockers as our next up grade then 4.10 gears. heads were done by KG engines 587 casting cnc 202 160 ferrera valves these heads flow up to 275 cfm according to Dave at KG engines. As for compression im guessing 10.5. We have a 26" drag radial slick outback.It ET at 103.37 mph
Slant 6 - 65 Valiant - 12.70 @ 104.6 mph
Engine is .084 Over , 11.5 to 1,Molnar rods with Wiesco pistons
Mike Jeffrey Head, Cam is @ .550/.570., 264 @.050, 3X2 barrel Webers
904 with 4000 stall, 4.30 rear gears, MT drag radials.
Car weighs @ 2850 with me in it.
I'm in the 12s! I now have a 12 second street car with Ice cold AC and cruise control for drives to the track.
Previous to this weekend, my best was 13.20 at 105 and change. Friday night I pulled back to back 13.18s and then a 13.11.
I went back to the track Saturday morning to enter Sportsman class for the first time bracket racing in my life. First pass was a 12.99! I did it! I broke that magic barrier. I followed it up with another 12.99, and then a 12.97. All at right around the 104 mph with amazingly bad reaction times!
So for first round, I decided to dial a 12.96 hoping for marginal improvement again due to the air cooling. We'll I lined up with an old Fox Mustang running 14 something and I broke out by 6 frigging 10ths! That's right, I ran a 12.90 @104.92 (with a .4818 reaction time, but we won't talk about that!)
Never been happier to lose at anything. Regardless, the car still has lots more potential for improvement, but the driver, he may be a lost cause!
Cley
CleyView attachment 1716435155View attachment 1716435156
Very happy for you Cley! I know you pressed hard toward this moment
it's a great feeling to hit the 12's. what did you change from friday night to saturday to get into the 12's?
The track was way better as it always is for a regular race day vs t&t. Raised the rpm at launch and still stuck the tire. Went from 2.01 60' to 1.81 60'. Also I sealed the carb to the hood scoops fir cool air. That alone improved me over 1 mph on back to back runs. Now I have to keep all that stuff The same and whittle down my rt!
Cley
Ok my 12 second combo and I'm sure there's more with some tuning as this was first time in almost 10 years this thing saw the road. (25 year old build)
1971 Demon 340
1969 engine with X heads (Hughes Stage 1)
rebuilt stock short block
Hughes HE3038AL Hyd Cam 230/237@050 .515/.535 stock 273 rockers
35 year old Mopar aluminum intake, dual plane with no numbers, just says "Mopar"
Edelbrock 700 AVS
MSD 6 distributor and Box
1-5/8" Hooker Headers and 3" stainless exhaust dumping at rear axle.
904 TF and 3400 convertor
3:91 posi
12.57 Best ET @ 104 and a 1.70 60ft
Was going to insert a video but obviously not smart enough LOL (something about the extension: mp4))
1971 Demon 340
Edelbrock 700 AVS
3:91 posi
Was going to insert a video but obviously not smart enough LOL (something about the extension)
We need a picture of that Demon!!
1971 Demon 340
Edelbrock 700 AVS
3:91 posi
Might have to be a Gold Member?
I’m not sure.
Finally got our 1980 Dodge D150 out to the track again. A few small changes and YES! We get to post it here!
  • 200,000 mile 5.9, never pulled the oil pan. Oregon re-grind cam, Hughes valve spring, and a four barrel.
  • Hughes off the shelf torque converter in front of a free bee 727 that was headed to the junkyard that I did nothing to
  • 430 gear with a 29 inch tire
