MeucciGarage
Mopars Unlimited Seattle
Ok guys i need some help but before i start i wanna say that im 18 and still learning so bare with some possible stupid questions
Anyways..
I pulled the gauge cluster out of my 76 Plymouth Duster to replace my headlight switch. after replacing the switch and plugging everything back in the way i took it apart and making sure everything was plugged in all the way i discovered that my electronics all worked except for one taillight (pretty sure its just a bad bulb open to advice on that if you have it tho) but as soon as i turn the key farther to start the car everything dies. all electrical turns off and it doesn't crank at all. i charged the battery re checked the wires and all seemed fine. i am truly lost and wiring is a weak spot of mine. if anybody has pictures of how each wire goes in (like that big gray round one) that i can double check with or any tips on how to fix whatever i accidentally messed up id greatly appreciate it.
Anyways..
