ESP47
hell I see no reason you couldn't wing it over with the starter. just jump the terminal on the relay. ( and make sure everything is clear )
You could but if I was going to take Rusty's advice, I would turn it over slowly by hand just to be sure. You're basically using the rings to clean the cylinder walls so I'd go easy on that with the initial first few passes.
