3406pk
I'm ready to assemble my 340 engine from 72 Challenger and have a few questions. First I want to thank guitarjones for his oil mods thread and krazycuda for front of engine assemble for the proper way to prep and assemble those parts. Their tips were very helpful. I find all discussion here very helpful and thanks to all.
My questions now are on assy of bearings and crank. Do the bearings go into block & caps dry or do you use any lube. Also before crank goes on, what lube on bearing surfaces. Burt in "How to Rebuild SB Mopar" suggests Dry Film Graphite coating. I used Lubriplate white lube in old days last time I did rebuild. What do you suggest now. Thanks for input.
Build is 72 340 block bored .030, Speed Pro forged L2316F pistons for 9.4 CR. Stock J heads, Hughes cam Hyd flat 2024. Going to be street cruiser only w 4 spd mostly stock.
