mopardude318
What!!!???? The link doesn't work!!!! I must hear!
Not bad..but i'll bet you have a lot more time porting wise in those heads then it'll take to run those numbers with very mildly ported edelbrocks..
Brian
What kind of 60' times with that motor and how do they compare to the 360 you had in the car?
Dang Brian that car gets down!!!!
Sounded like you got it to 3rd gear. What was the RPM at the trap with the 4.56's?
Those heads are RHS just like we sell, no porting what so ever! When the article hits the stands you will see exactly what's in this engine.
I didn't even port the intake manifold! LOL!
Nicely done Wylde.![]()
You'd spend 400-600 porting a set of Ede's to get the flow rates of the RHS heads. Plus, fixing the screwed up valve job they usually come with. Let not forget the better spring and ferrea valves OU812 installs, you'd be in 2500+ on a fresh set of ede's to match these RHS heads.
Got news for ya' Edelbrocks come with the good valves also,and i am nowhere near that amount with my edelbrocks they are out of the box very mild clean up...
These heads are fricken amazing! I REALLY want a set for my 318!!! Brian, are you gonna be at spring fling??? LOL!!
