MoparOrNokar
HammerTime
Just curious to how many R's you can put to a stock 360 crank and rods
Oiling mods are suggested for rpm's north of 6500.
Exceed at your own peril!
"10,000 rpm !!!!!"
Where can I get a cam for that?
Would I still have a nice lope in the idle?
Do you think it would be hard on gas?
My neighbor says he can tune anything. Do you think he could handle that?
What part number would the springs be?
Would I need H-beam rods for that, or are my PN 2438679 rods OK?
A guy I work with says I might have a hard time to balance the crank for that. Do you think thats true?
I have a set of custom pushrods left over from another job.Do you think I can make them work with aluminum roller rockers.
Tuesday morning. Semi-retired.Still making trouble. Somebody has to......
Will that work with my 2800TC, and 727
Where can I get a 7.56 rear cog?
My intake is only rated to 7000 or so. I cant seem to find any, rated higher.
Do you think my 750DP will be all right.
I just bought a new dizzy. Can I transfer that over? Its the vacuum advance kind.
I just had my Magnums ported. Do you think they'll be ok?
I just heard my neighbor leaving for work. I think his 4 banger turns at least that, so a V8 should go double, right.I hate the sound of that guys tuner pos.
You're. talking overkill,You can get by with just a tack weld!12,000 PRM !!!!!
You've got the parts!!!! But you might want to weld the nuts onto your rod bolts!!
I so, so, love this forum
Ps I have no budget in mind yet, Just trying to figure out what parts I might need. I might have to sell my Caravan tho,to make it happen. Yeah old Betsy, shes in pretty good shape for an 84. That should about get me some heads I'd think.
