beefovail
Active Member
I am trying to redo the rear brakes on my dart and I am quite confused at this point. The shoes are 10x 1-3/4", drums are 10x2". When I pulled it apart the shoes and drums were hashed, with a diagonal wear pattern on the shoes? The shoes do not fit the backing plates and appear to be to small and when installed where they should be, there is about a 3/8" gap between the shoe and the backing plate where it should touch the backing plate at the pads. The drums do not engage the backing plate when installed. It is almost as if the backing plates are for the bigger brake setup, with the smaller brakes installed???
I just bought the car and have no idea what the rear end is out of. The car was a /6 originally, so I doubt the 8-3/4 was stock. It is the small bolt setup so my question is what size should the rear drums be? It is a 69 dart. I know I should swap it over to the BBP axles, and probably will when funding is available. For now, I would just like to get some brakes that work and are safe and drive the car. Any suggestions would be greatly appreciated. I am getting frustrated trying to figure this out.
Thanks
Keith
Thanks
Keith
