Stop in for a cup of coffee
So anyone here know boat engines very well? I am now the new owner of a 1984 Mercruiser . It was my grandmothers boat she got before her dementia got really bad a few years back. Today, my grandfather out of the blue gave it to my kids and I after we got back from a weekend on the lake. It’s been landlocked for nearly 4 years now with an over heating problem we cannot seem to solve. It’s an In-line GM 6 cylinder. 251 I believe. We’ve tried removing the thermostat and that didn’t help. Compression test came back A ok. It’s a water to water radiator system, sealed system of course. Water pump does appear to be flowing the coolant. No coolant leaks. No oil leaks, but it gets so hot so quickly it quite literally boils the gas in the carb. We have no way to run it out of the water. Anyone got any thoughts
The carbs need to be rebuilt first an foremost to get the engine running in normal heat balance. The overheating bit follows. That part is most likely the fresh water heat exchange pump and plumbing.
Awesome thanks! Think putting a spacer between the carb and intake will help the heat soak any? I have plenty of clearance to do such
A closed system? It has a radiator? You sure? Rare to have. Most use lake or ocean water to cool.....
Like this
78094 Mercruiser Heat Exchanger.
A closed system? It has a radiator? You sure? Rare to have. Most use lake or ocean water to cool......
Yep, surprised me too. Water is sucked in down by the prop, passes thru a pair water to water radiators, one on each side of the rear of the boat, then passing into the exhaust manifold, back out into the water. Each radiator is full of antifreeze and that flows to the water pump and into the engine. Lake water itself never enters the engine
If i recall it has a heat exchanger.
Screens in it. They get sanded up and no more cooling water.
BUT you need lake water to cool the engine water. Water to water cooler. no lake water, no cooling.
The lower unit has a pump, impeller if you want to get technical. Then it passed up a tube where its distributed through the heat exchangers. There should be a telltale that water is flowing, like the outboards have.
Is there a way to test this on land? I thought about sticking the prop into a 55 gallon drum filled with water
Just got in the house a little while ago. Long day in the shop.
Not very often im out working until 8:30.
Trailer is getting there...
Then pulled the dodge in the shop, and got a confusing issue with wiring diagram figured out.
We run outboards on land all the time. Usually a garbage can.
The perfeshunals use a heating oil tank cut to fit the motor in.
