Unconventional
got there afterall bummer
Got the tires swapped for the customer,while i was in tire mode,put the 265’s back on the Fargo. Road test,it drives fine.
Moved some stuff around the yard and pulled a couple 10 foot trees out with a chain and the tractor. Went for a ride to town, and its getting warm out.
Come in house,its chilly,temp is 71 degrees and thermostat is set at 66. Wtf? Will be chatting with someone soon..
It's one of those years!O joy it's pouring again.
I have issues with that here. Just 1 degree at a time until it get's comfortable. 10 degrees may take days to cool down. Mine is comfortable at 77°. A degree or two less is quite chilly.Got the tires swapped for the customer,while i was in tire mode,put the 265’s back on the Fargo. Road test,it drives fine.
No biggie. Moved through pretty quick. Cooled it down a bit.got there afterall bummer
Didn't know you needed those. What project Tim?Found a fan shroud. And a 8.75 center section sure grip with 3:23 gears. Fresh. Clutch type section. 742 case.
You coming back tomorrow?We came home...too hot
I heard a lot more like normal. Lot's of vendors and lots of people.How’s the traffic been? Back to normal or still minimal crowds?
Good goodI heard a lot more like normal. Lot's of vendors and lots of people.
They spent it all on lumber…Not much money changing hands though.
Good Morning from cool and sunny Carlisle!
