Stop in for a cup of coffee
Sorry for your loss Red. It seems most of us are at that age where we are losing close friends and family members. It doesn't make it easier. I know when we were expecting my Mom to pass it didn't make it easier. You will be in our thoughts
Mornin' c\_/ . Agreed. Not many left to loose. Odd as it seems, my neighbor Ray called Tues' evening to tell me the neighbor Weaver behind us passed 9:20PM Monday. I replied, Uggh my pop passed about 2 hours ago.
well.. and my gas gauge rarely drops below full... i just put in 5 gallons.. it went from full to.... full :)
Mine stays on full for a long time, then you can watch it drop to about 1/4, levels off some. It is the cut out for the spare tire
Sorry for your loss
yeah, mine is a normal square tank.. if i drive for a bit the gauge will start to move but just barely below full.. i think 5 gallons gone should have moved it, still don't know where it's at. i didn't fill it up, just put in $20.. I'm super paranoid bout running out of gas, i would rather the gauge showed empty early, no issue there, showing too much gas is just trolling me into having a 1 man car show on the side of the road :)
Just found this pic.. guy did a "Carb swap" and the electric pump died... so i assumed he went with a EFI setup... nope.. electric pump with a carb.. why? I will never run an electric pump unless i have to.. it's just gonna die
When it rains it pours. Hang in there
Totally typical for the later 13 ohm gauge. I'm not really shocked since I'm human too but,,, thevgauge that never was really accurate throughout the scale wasn't complained about so much back in the day. Once a aftermarket sender is installed we watch it closely and pitch a ***** about how inaccurate it is. HELLO , it's only a little less accurate than it was before.
I have an electric pump in my Fargo. I have no idea why i did it. I think it was because i put it in as the flathead fuel pump was bad.
yeah.. i just don't trust electric (unless it's in tank and oem quality) but the ones that hang off the frame.. nope.. plus the sound of like a Holley blue makes me nuts
I used the gas tank and gauge from a mid 70’s pickup in the Fargo, its pretty accurate. And the electric pump gets noisy if it gets a gulp of air.
I have one in my '68 F250, as the FE motors are notorious for heat soaking the carbs. So far, so good....
As long as the gauge goes down as the gas get's used and it registers empty when the gas is close to gone I'm happy. You must have a aftermarket sender.
Knock on wood, both the gauges in my 2 rides are fairly accurite. Original one in the Swinger I imagine. No Idea what's in the Polara but it does work. Full is full and empty is just that.
Morning!
Sunny, calm and cool. Should get this Hyundai done today. Re- inspection tomorrow i hope.
Damn grass, my yard is turning into a jungle..
Morning!
That Hundai looked like a mess but any wiring harness does with no covering on it. I need to get one of mine mowed today too before I have to buy a baler.
You have to love the new soy covered wiring they use in cars. The mice also love it!
The Ag manufacturers started using that a few years back. It's like WTF. And all the new ag equipment has so much electronics and miles of wires.
I sold a lot of wiring tools to the ag techs though.
