Stop in for a cup of coffee
hmmm just acquired a piece of 4x8 stainless from a buddy of mine, 1/8th thick.... what to do with it
OK. Here's a question for you bright welder types..
I took a disc from a plow and welded some steel in the center to make it solid.
This thing is 1/4" thick. I'm guessing the disc is hardened/high alloy/fancy crap steel. The filler material I used in the center is just 1/4" mild steel..
The problem is when the welds cooled off, it cracked like hell.. Any suggestions how I might pull off a decent weld that won't crack?
most of your disc blades like that are 4130 chromemoly...... you'll need to tig it
Heat it first and as it cools you keep the heat to it and control the cool down. Plus I would use a harder rod. 7018? Or are you MIG welding I have been fighting my Mig welder for the last hour.
I was MIGing it... I tried using a really hard rod on it... But it just got wet..
wow.... get this, they're reporting that flight that killed that soccer team, the plane ran out of fuel. I guess the flight plan from the very beginning was actually longer than the maximum range on fuel that plane could carry and they didn't plan any refuel stops...... :mob:
