ScampMike
Despicable Damn Yankee
nice! enjoy!Time to go... Goin over to my Daughters with all the Family for a git together,,,
Getting deep in here
Make Frisbees!hmmm just acquired a piece of 4x8 stainless from a buddy of mine, 1/8th thick.... what to do with it
Sounds like a new x-game idea!Make Frisbees!
thats a great idea!Dash?
OK. Here's a question for you bright welder types..
I took a disc from a plow and welded some steel in the center to make it solid.
This thing is 1/4" thick. I'm guessing the disc is hardened/high alloy/fancy crap steel. The filler material I used in the center is just 1/4" mild steel..
The problem is when the welds cooled off, it cracked like hell.. Any suggestions how I might pull off a decent weld that won't crack?
Yucky... I ain't tig-worthy!!!most of your disc blades like that are 4130 chromemoly...... you'll need to tig it
Not a big wing fan,(lot of work for the amount of meat) but man were they tasty!
Heat it first and as it cools you keep the heat to it and control the cool down. Plus I would use a harder rod. 7018? Or are you MIG welding I have been fighting my Mig welder for the last hour.OK. Here's a question for you bright welder types..
Either that or not let it get so hot when welding. Just short spots and let it cool between. Just a guess, something to tryHeat it first.
I was MIGing it... I tried using a really hard rod on it... But it just got wet..Heat it first and as it cools you keep the heat to it and control the cool down. Plus I would use a harder rod. 7018? Or are you MIG welding I have been fighting my Mig welder for the last hour.
you REALLY need help!I was MIGing it... I tried using a really hard rod on it... But it just got wet..
I get that a lot!!!you REALLY need help!![]()
