Nah, it won’t work. While they blow plenty of hot air, it has no substance. There will be nearly zero effect on the real World once it’s diluted by true substance.
That is THE reason the Northern most states use sand and gravel. Salt simply doesn’t do anything at those temps. At least the sand and gravel can improve traction.I always understood that was one reason much of New England used sand and gravel, not salt. And that was true in parts of NJ too, even when I was still living there.
But I don't know if that wsa the real reason or not.
Bet we'll see examples of it - at least around here. Just because it wont work won't stop people from hoping it will... sigh.Even that won’t work. There is no molar concentration high enough to work at those temps. It will have to melt the ice and have the water sublimate before it all refreezes.
No doubt. The thing is that when temps rise above 16* on Monday and it starts working again, they will all believe it was working all along.Bet we'll see examples of it - at least around here. Just because it wont work won't stop people from hoping it will... sigh.
That also has to help in keeping the snow from turning to ice when compressed by the tires.Too cold in winter and way less traffic than here..
No doubt. The thing is that when temps rise above 16* on Monday and it starts working again, they will all believe it was working all along.![]()
I melted plastic to seal the bottom of the Duster overflow bottle. Best glue I have found for plastic - JB Weld 50133 plastic bonderSpeaking of melting, here's a little experiment with plastic to repair a bulkhead connector.
Acetone had no effect. Crazyglue had some bonding but no strength. Guessing it may be nylon.
Cut some pieces off of another that was broken and melted it into the crack with a hot knife tip on butane soldering iron.
Back during the Winter of the Polar Vortex, I saw more than a few radiators explode while people were driving down the interstate.
I'll see if that's the same JB as I tried using to fix some parts on the wagoneer. It worked OK, but have had better luck with two part permatex plastic glue. Got pics somewheres. Cant find right now.I melted plastic to seal the bottom of the Duster overflow bottle. Best glue I have found for plastic - JB Weld 50133 plastic bonder
Keith - I may have an '73ish era overflow from a slant six A-body.I melted plastic to seal the bottom of the Duster overflow bottle. Best glue I have found for plastic - JB Weld 50133 plastic bonder
The one that scares me when I think of it is the nylon nut that hold the spare tire carrier under the wagon. I fixed it with that permatex stuff and then reinforced it with wire a number of years ago.I think the rockheads had plastic/nylon screen material that could be repaired with the proper filler material, don't recall what heat source was recommended. They didn't let me play with too much plastic, 375* rock and oil don't get along well with that stuff.
Waaay back when (probably 1980) I had a 1974 Datsun B210 that had weak antifreeze in it and overnight on a frigid night, the coolant froze.
When I started it in the morning, the belts were squealing like mad because the water pump was frozen and wouldn’t rotate. I pulled the belts and ran the engine for about 10 mins at a time for a few cycles to heat everything up until the pump melted enough to rotate. Then I put the belts back on and repeated about 5 more times until I got everything warmed up enough to melt all the coolant.
I missed school that day, but at least I got it functional enough to be able to go get fresh antifreeze and replace what was in the system to give proper freeze protection.
Ever since then, I am hyper aware of the coolant condition in all my vehicles.
I had a 74 b210 too. Fun little car.Waaay back when (probably 1980) I had a 1974 Datsun B210 that had weak antifreeze in it and overnight on a frigid night, the coolant froze.
Some of the best lessons Dave. We teach ourselves the hard way. LOLWaaay back when (probably 1980) I had a 1974 Datsun B210 that had weak antifreeze in it and overnight on a frigid night, the coolant froze.
Thanks. I already have a spare from the one I parted last Spring, but the repaired one has held up and looks good.Keith - I may have an '73ish era overflow from a slant six A-body.
