Unconventional
It's Fiat Friday!
Good morning.
Time for the PT torture.
Clay bar.So, there is an unknown film on the windows of the Demon, likely due to sitting for 35+ years. Any thoughts on something safe to use to remove it? You can feel it with your hand (Karl). Windex and straight alcohol doesnt cut it.
lacquer thinner, clay barSo, there is an unknown film on the windows of the Demon, likely due to sitting for 35+ years. Any thoughts on something safe to use to remove it? You can feel it with your hand (Karl). Windex and straight alcohol doesnt cut it.
First, a razor blade. Then the above^^^^So, there is an unknown film on the windows of the Demon, likely due to sitting for 35+ years. Any thoughts on something safe to use to remove it? You can feel it with your hand (Karl). Windex and straight alcohol doesnt cut it.
It wont scratch the glass, Razor blade.....Thanks guys. Was just trying a razor blade in a small corner.
Strange, I thought all along alcohol was what fixed everything....huh..
Usually with a mixer....Thanks guys. Was just trying a razor blade in a small corner.
MEK.
Only causes slight brain damage if you drink it.....MEK.
MEK.
Only causes slight brain damage if you drink it.....![]()
That stuff is wicked nasty...Note to anyone reading. 80 deg and cleaning windows, especially inside carwith MEK is brutal. Use a fan!!!
Breathed in so much of it in the NAVY It's a wonder I can think at all......Some will say I can'tOnly slight? Beyond that already so I should be fine or maybe improve..
Less then yours?Define slight.
Lol
INSIDE?Note to anyone reading. 80 deg and cleaning windows, especially inside carwith MEK is brutal. Use a fan!!!
Hey Keith. I made some shelf space for the Hoppy this morning. Finally.INSIDE?Not good...
???the Hoppy
But did you use it ?Hey Keith. I made some shelf space for the Hoppy this morning. Finally.
