Sooo Since I bought my 5th wheel, the black water valve has had a slow leak. Ordered new valve, took out the def valve, the seals were not installed correctly. Well, WTH, no way to install the new valve without cutting two PVC pipes, and then having to repair the cuts!!!! Those designers could use some learning IMO.
They glued everything together, with no room for slack. Need 2 inches of slack to get valve in the proper spot. No way near that. Just what the valve thickness is, that is all the slack....
