It just might be. I like your way of thinking.Sounds like lift day 3 is brewing in the coffee shop
I though may be you groomed your lawn. LOLI cut the grass. I don't live in those type neighborhoods where they mow the lawn.![]()
Que Karl. Oh you said brush and not bush!I brush hog most of my yard...Good Morning
I need to check on the drain and sewer. The building is in back, sewer line is out front.Craig Since it is new construction theres a ton of stuff I should have done. Running water, floor drains, translucent panels on the sides, spray foam etc. 220 3 phase is pretty much a must for a decent compressor.
Just for that reason!Que Karl. Oh you said brush and not bush!![]()
French drain, doubt you can hook up to the public sewer.I need to check on the drain and sewer. The building is in back, sewer line is out front.
Good idea, but I'm not sure what the city code will allow. I'll just have to call and check.French drain, doubt you can hook up to the public sewer.
Yes gas heat and a AC unit. It will also be super insulated.doing heat/ac in it?
I would do at least 3 feet. That’s where we put ours and I still wish we had more room to walk around that sideGood Morning.
Hey while your grazing on that great looking muffin I have a question.
I'm putting a lift in my new garage first space near the left wall.
How much space from the wall to the far side of the lift does it take?? 15"??
Just trying to plan.
I think I was going 30x40. I might just go 35x40 and add a little storage space for one end, and a man cave on the other end.
I have decided to go wood frame. We have trees in the backyard. They will be trimmed back, and one removed before construction. If a limb fell you can repair a wood frame, not so easy with metal.
A 5 horse 80 gallon is a great sized compressorWe were walking last night through the neighborhood. A guy was out working in his shop and it was brighter than a sunny day. I'm going to have to stop by and see what he had for lights. I want plenty of lights and plug ins. And a nice sized air compressor.
I bet corn cob lights...DDaddy Dave turned me on to them. WOWWe were walking last night through the neighborhood. A guy was out working in his shop and it was brighter than a sunny day. I'm going to have to stop by and see what he had for lights. I want plenty of lights and plug ins. And a nice sized air compressor.
I have a two stage 220vt 7 1/2 Hp Ingersoll, with an 80 gallon tank. I built an insulated shed behind the lift bay wall, and piped it inside. After the air comes in, it goes to 2 extra 60gal storage tanks...I NEVER run out of air....A 5 horse 80 gallon is a great sized compressor
Cheryl wants a frig, chairs, and a big screen ty on the wall.When my Ex saw my Garage, finished product, She Crowned it the GarageMahal........![]()
