Why would the neighbors wife flip out over you having a survey done?
They must be guilty of something...
One of the best things about 2nd shift. Always have daylight on MY time. 3/4 of my work hours are after dark.
I managed to do a few things on the 71 swinger but found that I now have more to fix.
Both front upper ball joints, missing brake adjuster parts on drivers rear and maybe a broken ring and pinion in the 7 1/4.
I can jack up the rear of the car and turn the driver side tire and the other one turns the opposite direction as it should. The thing is the driveshaft doesnt turn with them.7 1/4 axles are weak... I broke many of them with a mild 318 4 bbl....
I run 8 3/4 axles now...
Unless the earth decides to break out of orbit and we go off into oblivion...This gettin' dark at 4:30 is gettin' old already and the days keep gettin' shorter for 20 more days View attachment 1715641309
Morning sir!!Morning folks. Thought I'd get an early start on Thong Thursday..
Spring for sure. Wiring to finish, couple coolant leaks and i have to revisit the brakes. Then a little paint inside and some trim and upholstery.Nice. When do you think it will be done Frank?
That's be cool, too.
And here is another scam. You get started then they start taking from your credit cards $200 at a time. Then try to get it cancelled!Babbel is having a 60% off sale on Language lessons.
One of these days I'm going to do the Spanish.
About to go to sleep here.Where is everyone?
