Dont know why im fixing the beater. But i need a plow truck.
I put a small point of use electric heater under kitchen sink. Works greatI wish I had a booster for the kitchen sink. It's a long way from the water heater and on a north wall. Some simple 110 volt unit. I thought I saw one for sale somewhere.
What does it look like? InterestedI put a small point of use electric heater under kitchen sink. Works great
Thanks Tim. Something I need to check on.
On?Hi all, got the new ball joints and bushing pressed in. Just laid the first coat of primer down too.
I’m thinking of doing this in my camper and ditching the tank water heater that’s in there
Anyway it’s done...That one that Tim posted was 220v. Is your camper just 110?I’m thinking of doing this in my camper and ditching the tank water heater that’s in there
Just resting the back. Squatting those 400 pound rims took a toll on the old back and knees
That was fun. NOT! This definitely did not go as planned. The new install wasn’t bad, but getting the old one out was a muthaf@&$#! Luckily I got my project helper buddy Stefan over for the assist. It would not drain! Ended up cutting the bottom of the shell open a couple feet up. That drained the shell. Then drilled holes in the side of the tank. When we thought it was done tried to take it out. Has to go up like 5-6 steps. Got first no problem. Second one it shifted and locked the hand truck in place somehow. So, I held it while he came down around it. We just shoved it up and out over the hand truck. Then we flipped it and watched another 10 gallons drain out.Anyway it’s done...
I don't need a constant stream of blazing hot water but it would be nice to get 100°+ for a minute or two until the water from the main water heater fills the pipes.
Really? I would only think a few bucks max...I give my scrap to my neighbor anyway, so whatever he gets is his.Our old 75 gallon water heater fetched $30 at the scrap yard this summer....
When its slow in the office and someone is dozing, and the boss shows up..... we warn the dozer with a bird call. Caw caw, caw caw.
no, it’s both.That one that Tim posted was 220v. Is your camper just 110?
let’s see you do it old man
let’s see you do it old man![]()
Thats why i have a shop crane...I would get some young guys to do it for me... Work smart, not hard....![]()
75 gallon tanks are around 280 lbs...
Not sure if it was fully drained either....
Looked a few up and some are that heavy. All the 75 to 80s I saw are over 200 anyway. So, i guess with that water still in it, must have been 250-300lbs.75 gallon tanks are around 280 lbs...
