Stop in for a cup of coffee
Had to drag astro van closer to shop so i can plug in block heater and battery charger. Its still pretty cold. Fingers go numb.
So, what do you guys think of using this on new Trans hump,
Dynatron Gray Auto Seam Sealer Caulk
Then pop rivet it in, from the bottom, so heads are on underside?
https://www.autozone.com/sandpaper-...n-gray-auto-seam-sealer-caulk-12oz/167027_0_0
Or just weld it? With this sealer? Worried heat will degrade its performance...
I think the factory did spot welds through the stuff, but I don't think it's gonna hold up to mig heat. I did small welds with skips in between on my floor pans. Then used the Dynatron inside and use Black Jack Neoprene underneath. Much stickier and flexible... Both are paintable.
Ok. My favorite cookies. Peanut butter. Somewhere along the line it was decided that they needed vanilla. “Its in the recipe” is all i get from the wife. Today Kim decided to make them.you cant taste the vanilla she said. I can. if i wanted vanilla cookies i would ask for them.
so, i won! No vanilla. And they taste just like when i was a kid.
:thumbsup::thumbsup::thumbsup:
That round of snow is done and cleaned up. About 4" of fluffy snow with an inch of sleet on top. Might see a little mor between now and tomorrow morning, but not likely to total more than 2'. Traffic is starting to move better. Near time to go to work...
I always said best jobs are the one where you cannot tell what was done..
61° with zero wind :realcrazy: and the first time I've been in short sleeves in a couple weeks :rolleyes:.
Weather Service says 69° this afternoon? I think that's a bit of a reach for them.
Warm enough to open up the house and let it air out some though.
Astro van. No fuel. Pump is bad. Thankfully he filled it with gas.
I asked sales person at Batteries + why replacement batteries don’t last as long as factory installed ones. He said when a vehicle is new things work easier and takes less battery energy.
:bs_flag:
I gotta call bs on that salesperson... His batteries are not as good as the originals if they don't last as long, period...
