Haha
It showered on and off all day here. LOL
Did you notice who the author is? Spanky McFarland was “Spanky” in the “Little Rascals.”
And you didn't slur your words.It showered on and off all day here. LOL
Ok Ray, what did you do !!Went to look at a church in the city, volunteer to do some work, on Saturday.
It's been closed a few years.
Yep, it burned to the ground yesterday.
Sad to see old buildings burn.
.......ah.......ok.. what ever you say .It burnt just from looking at it? Ummm
How tight was plug when it came out?So, looking at the trans, the input seal looks perfect and still has some greese present. I did see this pipe plug looking like it was loose. I checked a spare trans and this plug is flush. I took it out, cleaned off the Teflon tape, used pipe paste and reinstalled. Now it went flush. Could it be the source of the leak?
You replacing seal while its out?
I would.
The other possible leaks are pump housing bolts and out the case vent.
Overfilled will cause foaming and it will burp out the vent. It will also foam if the fluid if its low.
I hope the plug solves your issue.
