Stop in for a cup of coffee
I called every place up here and the last guy I talked to said the last person who did it up here died. then said good luck and hung up.
Welding shop. There has to be someone around with a tig welder. Its the “in” thing now, being able to weld aluminnium.
i used something similar to muggy weld to fix a pinhole in my brand new aluminum rad. Can’t get muggy weld here.
There is a double jointed spark plug socket for that pesky #3 plug…havent used mine in eons..
No worries, I got it done, by turning the steering column to a flat spot. Used a universal 5/8 plug socket...BUT...Not so easy....
even if it's the tubes Inside the radiator leaking? won't they have to take the entire thing apart?
Tubes inside? You lost me. If its leaking, perhaps you can get warranty? An inner row of tubes leaking with no external damage, i’d try it.
They just need to remove the tanks and solder the leaking tube closed on both ends..
apparently welders don't work mondays
Definitely good to get outdoor stuff done early.
My brother's work has been sending staff home early. 18th century mill...so there's no real climate control going on.
Jack and Jill worked at the mill...
Until the work did slack off...
"I can't decide", the miller cried...
Whether to lay Jill or Jack off...
I found out on the late local news last night that the SpaceX Falcon launch today was scheduled for yesterday. The launch commander scrubbed it at T-46 seconds :eek: no reason was given for the abort order..
Don't tell SCOTUS that you had to abort it... :rolleyes:
I toss in a couple of things that I can always use. Added one more set of jets and 2 cans of degreaser this time
Good for them, I just spent an extra $32 to save $12 :realcrazy:
To quote Gallagher the comedian...
"Women can save you money buying ****"....
Some peckerhead has been calling repeatedly,wont leave message. Im not answering as i prefer not to deal with him. He can’t be trusted. Besides, i have been sawing and hauling trees. But i cant lift my legs anymore. Tripping on nothing. And its hot.
Saw works better than i expected.
That was me... :poke: :D
OK cool...
I've come to sorta expect being an oddity because it all sits on top of a 225 slanty... I've read a lot of the threads on here concerning carburation on these (particularly 4bbl /6 setups). There's usually a fairly vigorous discussion that occurs :rolleyes: with opposing factions. I have some folks that I lean toward their opinions primarily. .
"Lean toward their opinion"... Nice pun... :D
