can't tractor it?Yep one more day worth! I get to shovel gravel all day by hand so doubt I will be holding any wild parties this evening. I am too old and fat to shovel all day but my wallet insists that I do it myself! Hah!
You took a dip in the pond Way????
Look at some decomposed granite. Basically just a really coarse sand with square corners. It don't move much once it's down.I can use one more load of gravel. went in the pond yesterday. Dam the bank of that clay, slippery as hell. Figure drop some gravel on it.
If I recall correctly, pain relievers such as Excedrin have caffeine in them. Evidently the caffeine increases the effectiveness of the pain relievers. I’m not going to pretend I know how or why, some kind of chemical voodoo.Morning!
Trying to rain here.
Rough night is an understatement.
Why would coffee cause the pain to taper off? Seems to every morning.
I sure do wish I was setting with you for coffee, they ain't seen nothing if they haven't seen you and toolmanmike and I together, I would give up all my mopar dealer signs to be there Pete, hope you can cover for me this weekendMorning Mike, Mopar show weekend, sure wish you could be here
Sunny 65. Coffee out back this morning.Hey Scott...
49°... and almost June. Of course I'll be wishing for this come August.
you guys have some nice placesMy trans mount i bought got lost in shipping.. refund though so it's ok
Cracks me up that my trans mount is $22.. and motor mounts are 800...
They are called floating power mounts.. used on mopars til 61 but my 62 musta been a early build cause it has the 61 engine and trans mount.. the trans actually sits on a big spring with a rubber biscuit on top.. My motor mounts are fine luckily.. and if they do break their design makes it so you can just drill through them and make a solid mount, i would rather not if i can help it thoughWhich mounts are you looking at?
Me either.. i kept searching for 1962 mounts and kept getting normal ****... then i searched for 1961 and found the right stuff.. Also.. my 1962 service manual shows normal axles and i have flanged axles (which if i ever find a center section for a good price i will swap out)
Not very ambitious this morning, but should probably find something useful to do for a couple hours before work…
Halfway through second cup.Coffee....
That’s when I start thinking what comes next.
Halfway through second cup.That’s when I start thinking what comes next.
Took care of that when I was in to refill my cup.Usually a restroom trip
I need to get on some yard-work soon..
