Hi there,
first of all i am sorry for my english.
So here is the deal, i live in medellin colombia and im trying to rebuild a 318, the machine shops here are the worst you people can imagine( they will only use a micrometer if you force them to ) the dont use factory manuals to get measurements, clearances etc they build by guessing, you guys would not believe how bad the situation is. Blueprinting is something thas has never been done to no engine in this fking country...
So when ispecting the heads i found out exhaust valve guides needed to be replaced they had over 0.15 side play one bein as high as 0.21 so i send the heads to the """machine shop""" to have them replaced (not possible to get ovesise stem valves around here) as you guys may know after a guide is replaced the valve seat must be reground so they did a 3 angle "valve job"
When i got the heads back they indeed had new exhaust guides and refaced seats. The new guides where reamed out to get 0.15 side play :cheers: i payed for nothing O
... most of the reground Seats didnt seal and the ones who did didnt have consistent widths and caused some of the springs to "stretch" to theyr limit specification 1.687..
So i went to a different shop and got the exhaust seats cut to a single 45 degree angle and now they seal perfect and have consistent widths within specifications the problem is now tje valves are sunk beyond specifications and the valve stem is now protuding 0.030 more than they should the manual says to measure them with tool C-3968 and mill the valve stems untill they fall within specs but i cant get the tool overe here
does someone knows what the valve stem instelled height should be for a 318 ? And how much can i mill the valve tip without going beyond the hardened surface?? I want to avoid bending a pushrod or burning a valve
