Tape vs split loom
Discussion in 'Electrical and Ignition' started by Futzy1, Apr 15, 2018.
Let's make it official, tape or loom
  1. Non adhesive tape
    76.5%
  2. Plastic split loom
    17.6%
  3. Braided split loom
    17.6%
  4. Home depot great stuff expanding foam in every crack and crevis of you dash!!!
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. RogerRamRod
    RogerRamRod Well-Known Member
    567
    185
    Jul 5, 2011
    Chesapeake VA
    Local Time:
    12:30 PM
    Sorry for the late response, but instead of hot glue, go to Home Depot and get a can of great stuff. It will hold EVERYTHING in place, stop squeaks and rattles, and !!!BONUS!!!! provide insulation from the engine bay.
    Chevy guys say it makes great support for newspaper to provide a backing for your fiberglass mat when repairing quarter panels
    • Like Like x 2
    • Futzy1
      Futzy1 Well-Known Member
      194
      25
      Nov 11, 2016
      La quinta
      Local Time:
      10:30 AM
      ^^^^Love it
      :rofl:
      • Like Like x 1
      • Mattax
        Mattax Just the facts, ma'am FABO Gold Member
        2,112
        830
        Feb 7, 2013
        Phila. Pa
        Local Time:
        1:30 PM
        That approach - eliminating the weak connection at the bulkhead - is totally legit. How it was executed can be quibbled over. Going straight through, with a grommet, IMO is the best. Tap connects like the type mentioned are amongst the poorer connection methods in my opinion.
        One point of misunderstanding in that article. The fusible link, or any fuse/breaker is not sized based on the power source. It needs to based on the downstream wiring; and the wiring is based on the loads.
        • Agree Agree x 1
        • MrJLR
          MrJLR Built, not bought FABO Gold Member
          3,380
          1607
          May 14, 2015
          Chino, California
          View My Photos
          Local Time:
          10:30 AM
          I used cloth tape. ....i like the way it looks.
          Jeff
        • prorac1
          prorac1 Well-Known Member
          758
          303
          Sep 29, 2012
          Martin, Mi
          Local Time:
          1:30 PM
          Question reguarding non adhesive cloth tape.
          How do you all apply it? I've never used it.
          Tape the beginning, wrap the harness, and tape at the end?
          Don't mean to thread jack, just curious. Thanks. Eric
        • Futzy1
          194
          25
          Nov 11, 2016
          La quinta
          Local Time:
          10:30 AM
          THREAD JACK!!!!!!
          Just kidding. Here you go.
          • Like Like x 1
          • brian6pac
            brian6pac Well-Known Member
            2,011
            778
            Nov 15, 2016
            N.E.Ohio
            Local Time:
            1:30 PM
            Do it right the first time you will be much happier.
          • Futzy1
            194
            25
            Nov 11, 2016
            La quinta
            Local Time:
            10:30 AM
            So I just saw this literally on my way back into the house after "gettin it done." Lol.
            So I need some pink wire which I just could not find local, so I ordered that online. That should be in next week. Plus I'm going to be ripping all of it apart within a month so for now, I made a couple of notes in my log and subbed some wire color. Slapped it all together with crimp-ons, and threw some yellow standard electrical tape. (I always use yellow to flag an unfinished line.)
            It's less to get the stuff working and more to make sure I dont have any major electrical issues before I throw the ac in. Plus now I won't have to spend 20 minutes cutting wires out a harness when I do.
          • RustyRatRod
            RustyRatRod Just another dumbass. FABO Gold Member Technical Editor
            44,693
            8297
            Jun 7, 2010
            Georgia
            View My Photos
            Local Time:
            1:30 PM
            Who gives a SHIT if it has a "GM appearance"? Are you gonna die from that? Use it if you think it's easier to work with. Learn not to give a DAMN what other people think.
            • Agree Agree x 2
            • Like Like x 1
            • brian6pac
              2,011
              778
              Nov 15, 2016
              N.E.Ohio
              Local Time:
              1:30 PM
              If you don't care WHY ask the question,
            • KitCarlson
              KitCarlson Well-Known Member
              2,306
              268
              Jan 17, 2008
              Middle Tennessee
              Local Time:
              12:30 PM
              The use of crimp-on instead of solder is great. Solder is never a better solution. The use of uninsulated barrel crimps and heatshrink is tidy, and results in superior connection and insulation vs soldering and tape. The key is a good crimper designed for size and type of terminal crimped.
              • Agree Agree x 1
              • phaelax
                phaelax Well-Known Member
                225
                42
                Sep 3, 2014
                Ohio
                View My Photos
                Local Time:
                1:30 PM
              • Futzy1
                194
                25
                Nov 11, 2016
                La quinta
                Local Time:
                10:30 AM
                Oh man, who's ready to go down a new rabbit hole with me?
                So, luckily I while I have taped a few harnesses I hang har yo tape many. Tape width? Off the top of my head I would think the wider the better, but that at a certain point too wide would just be more likely to crease on you.
                And let the chaos once again ensue. Lol
              • Futzy1
                194
                25
                Nov 11, 2016
                La quinta
                Local Time:
                10:30 AM
                While I kinda knew this had the possibility of becoming a "ford v chevy" topic, and I may have had have my opinions going into it, I also consider myself rational and capable of being swayed by logic.
                That being said you may be happy to know my views have slightly changed. Going into it I was all about the split loom. I typically work on things that i need to tear back apart wire and rewire a few days later. However on my dart I'm going for a stock "looking" car (ie original am only radio, with hidden bluetooth/mp3 stereo.) That being said I'm going to split loom anything I think I might need to tear apart, but tape it once I know its "good."
                :thumbsup:
              • famous bob
                famous bob mopar misfit
                8,506
                1631
                Aug 14, 2011
                okla
                Local Time:
                12:30 PM
                The bradied stuff dsoesn`t look gm I vote for it, looks nice , works, and can be gotten back into easily.
              • furyus2
                furyus2 Well-Known Member
                1,644
                302
                Oct 30, 2010
                weeki wachee fl
                Local Time:
                1:30 PM
                Lh6 p
              • Futzy1
                194
                25
                Nov 11, 2016
                La quinta
                Local Time:
                10:30 AM
                Uh oh, let the bullets fall where they may. My old 73 f250 had an fe390 with 300k original and a granny granny that could drag a house off the foundation. I'd have bet my life on that truck (and did, more than a few times.)
              • JoeSBP
                JoeSBP RLTW!
                873
                352
                Jun 16, 2015
                NC
                View My Photos
                Local Time:
                1:30 PM
              • furyus2
                1,644
                302
                Oct 30, 2010
                weeki wachee fl
                Local Time:
                1:30 PM
                Sorry, that was a pocket text. Not sure what you thought I meant, but it was nothing.
              • 89on35s
                89on35s Inferno Red Duster
                832
                387
                May 11, 2006
                Martensville Sask. Can.
                View My Photos
                Local Time:
                11:30 AM
                I personally use cheap black hockey tape. If electrical insulation is required, I use heat shrink or good electrical tape first. I do not believe crimp connectors are to be feared or avoided if you have a good crimper and take care to ensure there are no errant strands of wire sticking out. While wiring my car, I have tended to wire things up sloppy to ensure it all works then go back and clean it up right once it all is proven out. One thing I have learned is make sure all your add ons are done before doing your final wiring clean up. I am on round 3 of cleaning up the wiring under the hood.
                Cley
                • Agree Agree x 1
                • tjpatte
                  tjpatte Well-Known Member
                  123
                  37
                  Jun 22, 2015
                  San Diego
                  Local Time:
                  10:30 AM
                  Lacing twine and a needle!
                  • Like Like x 1
                  • pishta
                    pishta I know I'm right....
                    11,244
                    1701
                    Oct 13, 2004
                    Tustin, CA
                    View My Photos
                    Local Time:
                    10:30 AM
                    cloth or non adhesive tape is easy to open and test, but the cloth does get nasty dirty and pretty much turns to tissue paper over time. split loom does look cheap but its easy to use. Up to you: functional or asthetic?
                  • halifaxhops
                    halifaxhops I guess I have a gold member no one likes? FABO Gold Member
                    40,182
                    9884
                    Jan 20, 2014
                    CENTRURAL, PA
                    View My Photos
                    Local Time:
                    2:30 PM
                    I had a engine fire caused by OEM tape that rubbed through a oem wire the thing was a fuse, use racers tape unless it is a 100 point restoration!
                  • 66Dvert
                    66Dvert speaker kick panels for my dart are good to go! FABO Gold Member
                    1,990
                    272
                    Nov 2, 2008
                    Webster , florida
                    View My Photos
                    Local Time:
                    1:30 PM
                    I use non-adhesive in all the front lighting/engine bay area and interior component areas. I use split loom or braided in add on's to lighting or accessories in the trunk area only Or if I'm going to be working on it or plan a future repair or upgrade (again trunk areas only for this.) like my 4 light conversion for my 66's that way I can add or adjust it easier than unwrapping the tape.
                  • Dusterdenovo
                    Dusterdenovo Contentedly Old School FABO Gold Member
                    550
                    715
                    Dec 10, 2011
                    British Columbia
                    View My Photos
                    Local Time:
                    10:30 AM
                    I used the non-adhesive for all my stock harnesses. Where I bundled several loose wires (for neatness mostly), or for mechanical protection I used the split loom.
                    • Like Like x 1
