The Building of the Blue Mistic
jrlegacy23
68 Barracuda
Laurens, NY
I have newly acquired a beautiful 1970 Dodge Dodge Dart from FABO member (bnichols). I had a 1972 that I was building, but it needed a little more work than I originally planned to put into it. I plan to lower the 70 a bit with Hotchkis in the rear and a HemiDenny coilover front K-Member. I also have a nice warmed over 340 with a 3000 stall A904 and a reverse maual valve body auto trans that I got from another FABO member (Old Mopars).
Here is the car that I am starting with:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
What John said...good looking Dart, just remember to watch out for the Snowball effect. At least you have several nice parts stockpiled from the 72' so it should go fast.
let the fun begin!
ya know...I'm only a couple hundred miles away...I could be there in about ..what?...nine or ten hours?
Thanks guys. I may have to take a trip with the car out to Columbus for the Nationals one of these years. I plan on having it done for Carlisle this year. But, like Ross said... snowball effect.
I just put the Grant Tuff wheel on the other day, I bought it on craigslist for $20 including the Mopar adapter kit. I will take a pic and get it posted.
We plan on making Carlisle this year with the boys
my wife wouldn't go near us....too much BS...not to mention the gas
Here is the $20 Craigslist Tuff Wheel installed. It definitely improves the interior, compliments everything nicely.
Before:
attachment.php
After:
The car was running like crap when I got it. The carb was running real rich. I bought the carburetor rebuild kit and pulled the carb off, rebuilt it, and put it back on. I had my son out in the car (planting the Mopar seed), and he was helping out as I put the rebuilt carburetor back on. Here are a couple pics:
I had him cap the inside of the tubing so it does not collect moisture and dirt in there:
I drove the car a half mile to his house. He welded everything up, and I drove it back home. The one thing I noticed right away was that the car does not get that slight Mopar front end twisting on acceleration.
lookin good. Comin along nice and quick.
Looks to be in real nice shape. I kinda like the sport mirror on it are ya gonna put one on the other side?
And the capin the connector is an awesome idea. Thanks for it
Bnichols, whom I bought the car from, put that on there before I bought it. I am going get one for the passengers side at some point.
Here are some finished pics. Just for anyone copying this, I did not weld the frame connectors with the car on jack stands. The car was raised on all four wheels when welded in:
I think that if I were to do it again, I would cut this part. Maybe I still will cut it out to make it look better:
After rebuilding the carb, I have found that the top was warped and could not get it to seal and stop leaking fuel. I ended up buying another carb from a member here. The engine is running much smoother and stronger, but I need to change the plugs now.
I took it down the road and did a little one wheel peel 100 foot burn out. The subframe connectors not only take that twisting out of acceleration, but it seems to put the power to the ground quite a bit better. I was not expecting that.
