RAMM
So like the thread title says this is your truly average Mopar smallblock that seems to be fairly popular. People ask for a nice 400HP small block street engine w/aluminum heads all the time.
This is engine I am about to test is representative of what I see many people asking about here actually.
'73 360 block .030" SRP flat tops 1/16" ring pack -.010" deck
Stock rods ARP bolts
Stock cast crank .010/.020 balanced
Comp 270H camshaft / Melling lifters
Crane Gold 1.5 rockers
Stock style pass car oil pan w/Mopar HV oil pump
Edelbrock RPM heads w/2.02/1.60 valves, springs w/good Viton valve seals
Edelbrock 318/360 Performer (ancient)
Holley 750 dbl pump/ MSD billet dist/Taylor wires
This engine should be close to 10-1 comp and pumps 175 psi in all cylinders as it is.
Hoping for a really torquey engine and 400hp or more (aren't we always hoping?) More importantly I want good oil pressure trends, ZERO leaks, ZERO blowby and ZERO unexpected/bad noises. What say you? J.Rob
I have a 340 that is almost identical to that build.
