Continuing to work on getting the engine and peripheral equipment squared away, have some details to update tonight.
First off, the fuel line was routed from the chassis to the engine. This wasn't a big job, just had to make the correct length hose. The fuel "log" that attaches to the throttle body can install either way. I tried it with the inlet both front and back but decided having it at the front was not going to work. The line would have had to go all the way up the inner fender which I've seen done but my preference was to keep it shorter. There is also a fitting for the EFI fuel pressure sensor that requires a take off line to the sensor. Keeping that line shorter is better for accuracy so the choice was made to pick up the line at the back of the engine.
I used some heat shield liner at the bottom where it's closer to the header. It would have been fine either way but I had the stuff on the shelf and better safe than sorry. Came out good. One Adel clamp on the inner fender and it's solid.
I had a 120º fitting left over from some other plumbing project that was put to use. What's nice about it is that it angles the hose slightly forward away from the firewall. Note the fitting with the 90º adpater on the bottom for the fuel pressure sensor line. The black tubing is for the MAP sensor which goes directly to the ECU inside the car.
Over the last few weeks I've been contemplating where to mount the EFI sensors (oil and fuel pressure). From what I've read, having them on the engine tends to shorten their service life. Mounting them remotely prevents premature wear and also helps them read more accurately. I got a remote sensor block that has provisions for two transducers that thread into it. The hoses coming from the pressure sources will attach to the two 90º adapters at the bottom of the block.
For now, the best spot for these sensors seems to be right above the master cylinder. It will keep the lines to them relatively short (as opposed to having it on either fender apron) and the wiring will also be shorter.
After the holiday I started in on mocking up the coolant hoses. I ordered almost everything from
Auto Plumb. Seems to be decent quality stuff and a tad less expensive than buying these kinds of parts from your parts house of choice. They do not carry any "Mopar" specific things so I did get a water neck from Summit. I think some SBC water necks are the same bolt pattern but since I wasn't 100% sure I
got the right one with some other things I ordered.
I went with -16 hose. Guess we'll see if it's sufficient. My radiator is relatively big and my electric fan moves a lot of air so I believe the -16 will be fine. I'm also working on a mounting solution for the electric radiator fan.
These adapters are a bit odd looking on such a long water neck but short of weld on fittings this is the only option if you want -AN type cooling hoses.
There are a couple other things currently in the works. I'm trying to decide how to handle the alternator charge wire. I am contemplating using a Deutsch firewall junction connector. I'm hesitant to use it though because it requires drilling a 1.25" hole in the sheet metal. I may have no choice about it though.
Currently, the charge wire is running through one of the unoccupied heater hose holes. Problem is still I need to run two 10. ga. wires into the engine bay for the radiator fan and water pump and the heater hose hole would be the perfect spot for those. The MAP sensor line goes through the one next to it. I may go through the heater motor block off plate but the way everything is situated behind it leaves me very little room. I don't want to take that all apart either so I have to mull this over a bit more.
Current possible spot for where to pass the alternator charge wire through the firewall. This is the connector cover plate.
Hopefully I've also figured out where to mount the air/oil separtor cannister. It is a bit clunky but also has to be relatively close to the valve cover and throttle body. It doesn't really matter where it is but as with other plumbing conundrums, the preference is to keep things as short as possible.
There is enough room here to make this work. The two existing holes in the firewall provide a convenient spot to mount an aluminum plate that I can bolt the cannister to.
I suppose all these little sensor gee gaws and the air oil can might seem like unecessry crap but I planned to use them from the start and they do serve purposes. The coolant hoses I just like because they look cool but they do save me the hassle of finding the right hoses with my non stock setup. Presumably they won't leak either and can be reused.
On a side note - I'm a little annoyed at myself for recently ordering two different things both of which ended up being wrong. With the carb spacer, I need taller studs. I had some already but they were not quite tall enough on the driver's side because I have a universal throttle cable bracket that takes up the rest of the threads with no way to get the nut on the stud. Dumb me ordered the exct same studs I already had. Doh!
I also ordered a tool for assembling the braided sensor hoses. Unfortunately I mistakenly ordered one for -6AN size hose rather than the -3 that I actually needed. Now have to deal with two returns to Summit and waiting for the correct stuff to arrive. Not a big deal but preventable. And again, I'm still waiting on two things that had to be drop-shipped directly from their suppliers - a 30" 6-rib belt and the -AN water neck.
Last thing was putting the torque strap in. I repurposed the sway bar mounting bracket for it. This has been on the car for years but it had to be modified to work with the QA1 K frame. Not feeling all that great about it. The threaded parts are closer to their ends now than with the stock K frame. Guess we'll see if it actually works with almost 570 lb. ft of torque on tap.
That's all for tonight. As always, thanks for reading. More to come.
