The Other 68 Dart Resto Project
flyboy01
Its almost done!
Dallas, TX
I am posting some pictures of my 1968 Dart GT. It was originally a 225/6 car, painted TT1 Med Green Metallic with a Dk Green Interior. The second owner did a "restoration" in 1990. He installed a 73 K-frame with Disc brakes and a mildly cammed rebuilt 318 4bbl with a 727 trans. He also installed a 69 A-body 8 3/4 and redrilled the axles for 4 1/2" BC. Then the car sat, it was last inspected in 1998, it had not moved until Dec 2, 2006. Then I bought it.
I saw it was on ebay and it was local, so i went to see it. I was shocked! I had never seen a car of this vintage with so little rust. Actually there was rust, but it was all surface rust, harly any pitting at all. The car was almost all there. The only missing pieces were the trunk finish panel and the glovebox. So I bought it. I got the high bid at $3750.
And so the project begins:
The restoration begins. I am thinking about renaming the car "snowball" since enertime I take something apart, I keep saying, might as well do this also.
I started doing a brake job so I could at least drive the car. Well I could not leave the drums looking like this, so I stripped them and painted them with rust encapsulator. Then I decided, since I was doing brakes, I might as well replace the rubber soft lines, so I did, with braided stainless lines. And, as long as I had the hard lines off the axle, I might as well paint the rear. So two hours later, I had the whole rear suspension off the car and only a gas tank hanging underneath!
I spent most of the day trying to get the years of leaking axle grease and dirt off the rear end, I am still not done, but I'm about 85% there, still have to scrub some crap off, but I am getting close to painting.
I wish my car was half as solid as that one! :headbang: Any ideas on what color you're going to paint it? I knew a guy 30 years ago who street raced one with a 340 & a 4 speed. It was orange & I always liked the look of it.
:burnout:
At this point I don't know. I might paint it one of the original 68 colors.
In order most likely colors.
1. TT1 Med Green w/Black interior & Black stripe
2. BB1 Black w/Red interior & Red stripe
3. LL1 Dk Turquise Metallic w/White interior & White stripe
And of course, Resale Red is still a possibility.
Looks like a solid car, it's a real bonus if you don't have to cut out to much or better yet any rust. My dad nearly bought a 69 Dart GT new, I was 11 at the time and was already envisioning myself behind the wheel in the not so distant future, the deal fell through and he ended up buying, of all things, a 69 Buick LeSabre 4 door, it still hurts everytime I see a Dart. :cussing:
Excellent score Flyboy. :thumbup: And keep up the good work. That is a really nice Dart.
I think LL1 is what PPG used to call Surf. My 68 2 dr post Dart is that color origionally. I repainted the engine well, dash, and the under carriage with it. It's a one year only color that is beautiful. I would go with LL1 and the black interior. :blob: Some day I'm gonna finish that car. :-({|=
Update, I got some of the suspension pieces stripped and painted, I also sprayed the rear leafs and rearend housing with rust converter, I will be doing the final painting tomorrow.
Actually, they look better now that the paint is dry, it looks like natural steel. You gotta love Eastwood. They may charge $18 for a can of spray paint, but they last forever, I can tell you how many parts I painted with one can on Encapsulator. I used about 1/3 a can of Chassis black on on my whole rear axle and leaf springs. They definately pack more paint solids into their cans than any other company. I hate to give them these shameless plugs because they pissed me off so many times with slow delivery times, but I have to admit, their stuff is the best. The only thing that I am less than satisfied with is their Rust Converter. It is too slick when it dries, you really need to scuff it up when it dries before you paint over it.
Upadate: Today I did the final assembly for the rear end, and stored it away in a corner of the garage. Heare is a picture of it detailed and assembled.
I also pulled everything out from under the back half of the car. Gone is the gas tank, filler neck, shocks, and driveshaft. Next job will be to sand down (or up?) the underside, give it a coat of rust converter, and then prime it with Rust Encapsulator. I think I should also replace the gas tank also, I took pictures of the inside of the tank, what do you think?
The project got put on hold this weekend due to a small disaster. I live in an apartment building, the bottom floor is where my garage is. Here is the story.
I came home last friday night and saw a bunch of people standing in front of my building with my garage door open and somebody inside my garage. I ran over and found out that there was a fire in the building on the third floor, so I ran up to check on my dog, she was OK, nothing damaged in my apartment, I was lucky, of the 24 units in my apartment building, 17 had significant water damage from the fire hoses and sprinklers. I had one of the lucky 7 apartments that the sprinklers did not go off in. Until I got down to my Garage, which was directly below the apartment that caught fire. I was not so lucky. When I got there, the maintenance man had already vaccumed out most of the standing water, a lot of my tools were soaked and starting to rust. I managed to get most of them cleaned off and dried out, my box of receipts that I kept for everything car or tool related is now a box of paper mache. All my new sandpaper ($100's worth) was soaked. My freshly painted and restored rear end was soaked and some small parts were starting to rust. My brand new 6" vice I bought the night before has a coat of rust. Right now I have buckets catching dripping from the ceiling and the garage smells horrible. Luckily for me, toolboxes have drain holes in each drawer, and the porous rubber matting kept my tools from staying soaked. I have to check my power tools though, and Im not sure I can save my dremel. I had the car windows open, all I can say is thank god for 1960's rain gutters, there did not seem to be any water inside the car, although my trunk was not so lucky since I left it open, I did have the drain pugs already pulled, but the clean, rust free metal inside now has a light film of orange rust. Also, thankfully, my new compressor was shielded inside a wood box, which also shed water because of the coat of paint overspray on top. Since very little was stored on the floor of the garage, I was spared the damage my neigbor had, he had probably a 100 cardbourd boxes full of all kind of stuff all stacked on the floor. I spent most of the weekend throwing stuff out and cleaning up. The Garage smells like a must basement from all the water that came down through the ceiling.
I decided, its time to buy renters insurance.
BTW, the fire was started by the idiot upstairs ironing his shirt and leaving the iron on his bed turned on! What an idiot! He could have killed people and pets in the building. Unfortunately, he was NOT removed from the gene pool last night. I hope they bill him for all the damage!
Wow, that sucks! Sorry to hear that ... but glad your apartment didn't get soaked. As for the car.. I think most of that is just surface rust and salvagable due to not rotting away.
Good luck with it all! Sorry to hear about your tools!
Well, everything seems to be back to normal now. It put a little delay in the process cleaning up.
Since then I have pulled, cleaned and repainted the driveshaft, replaced the u-joints with HD pieces. Cleaned all the gas tank hardware, painted the shocks, and bought new wheels and tires (Draglites).
The cold weather now has prevented me from painting the underside, everything else is ready to go back together now. Just need some 70F dry weather so I can finish up.
No progress, weather has been below freezing for a week, can't get my garage up to 70F to paint, so everything is on hold. I did get a new gas tank and 3/8 pickup/float assy though. I am going to have start finding other things to do until I can get +70F temps in the garage.
OK, i just took a serious left turn today. I bought a 383 w/727 trans. See what happens when you have idle hands! Now I got a big block Dart.
Just look at them below, so pretty, don't they look like they were made for each other?
I saw you on BBD.com. You have a 73 k member. Right? I put a 440 in my 2 dr post using the same k. When I droped the motor in it hit the k member and was crooked in the trans tunnel. I ground the lip off of the k member and welded it back up. Then took the drivers mount, you will need BB spool MM's, and sawed the front half off. Bolted the MM to the front side of the rear MM ear and then took the sawed piece and bolted it to the back side of the front MM ear. and welded it back together. Not a DC K member but it does sit straight in the trans tunnel. If you want to make the DC conversion go to the tech archives at BBD. I would have done that conversion, but it back before Gore invented the internet..ROTFLMAO.
BTW...do a search while you are over there so you will know how to do the B body headers in an A body. And great score on the 383. Wish I had one for my 68 2 dr ht Dart.
It's a good looking Dart, I'm envious.
So is the Eastwood spray on rust inhibitor like POR 15? Do you have to treat the metal first with etching stuff, or can you just wire brush/sand and paint away?
flyboyo1 glad everything is ok,and that guy never pick's up an iron again.
383 wow!! that' great,Hope everything go's smooth for ya :thumbup:
Here is an article on both, made my decision on getting Eastwood's stuff.
Its been a while since I updated this thread. Unfortunately my attention had been turned to my new 383 engine, and quite frankly, I got ripped by a chump on ebay. I was told that it was a running 383 when I bought it. WHen I got it home, I pulled the valve covers, there was a ton of rust covering the valvetrain, next I pulled the intake, rust in the valley, lifters frozen, cam rusted. I pulled the heads. WATER! In two cylinders, and in the intake ports. I pulled the drainplug from the oilpan, Oh My God! I scrambled to find containers for the gusher, my oil drain pan quickly filled with rusty water, I grabbed the lid from mt trash can and filled it. When the last drop tricled out, 4 GALLONS! I turned the engine upside down and pulled the pan, rust everywhere. I pulled the rods, the crank and bearings looked like they survived, the crank spun freely, so thing were not so bad.
I took the engine to a machine shop, they tore the rest of it apart, cleaned it, and told me that the block, crank and rods were good. I was going to have them rebuild it with new pistons and bearings, but I did a cost analysis. FOr them to do it with new pistons, bearings, rings, it would have cost me $1250. And I would still have a cast cranks, cast pistons, weak rod bolts, and an external balanced damper and TQ converter.
A lot of money for stock components. I did a little research, I can do the same machine work and a 496 stroker kit for $2050. For $800 bucks I can have an extra 113 cubes and another 125 HP. I cant do a stock 383 knowing that I can build a monster. The good news is now that I am going to get a monster motor, the bad news is that I am now going to have to wait until at least August until I can save enough money to do the engine and buy heads.
I had to re-evaluate my project, gone are my desire for 11 second time slips (for now). I decided that I am going to stick with my original plan and do the bodywork, paint, suspension, and interior. The good news is now I can afford to do all this by May. So now my plan is to get going on the pretty stuff.
Time to pick a paint color. It was between 3 colors, I think I decided on a color, PP1 Red. Tell me what you think.
Not my car, but exactly as I want it, see the car on the bottom row:
Update 2/26/07
I spent the better part of 4 hours on my back on Monday grinding away at any loose dirt, undercoating, and rust scale from the bottom of the balk 1/3 of the car with a wire wheels and drill. I am prepping everything for rust converter, followed by encapsulating primer, then paint. THis was the second dirtyest job I have ever done. There is no way to not "Get any on ya" grinding away on a creeper with the junk falling into every crevice in your head. When I finally gave up for the day, I walked in the house and my dog did not recognize me! Talk about dirty. If you need a godod reason to get a rotisserie, give me a cal I will give you a few. Next post will have exciting pics. :headbang:
Nice. Look at it this way: you probably got one of the dirtiest, nastiest jobs of the whole project out of the way. Piece of cake from here on out, right? :)
Nice dude! I have the same project going right now. I have a 68 w/ 73 K-member and discs, 8 3/4 rear, and dropping in a 440. The good thing is I'm in PA, about 10 minutes from the Eastwood showroom and warehouse. I can just drive up the street and pick up their stuff! I'm going to mini tub the rear and move the spring inboard. Other than that, it will look original.
Wow !!!! Sorry to read about the fire.Hope everything has turned out ok.
Going for the big block are ya.
If I had your 68 I would have a really tough time not doing a 68 Hemi Dart car.
Good luck with your project !!!!
