THOUGHTS ON SLEEVING?
Millions of ag and ind. engines have been cast for both wet and dry sleeves for over a hundred years at least or close to that. Here's just one example, Ford 8N types used factory sleeves and you can remove those sleeves and install with minor work fit in the pistons from auto/truck flat head V8's for a small boost in CID, compression and power. Those factory sleeves were a bit thin and I have seen them crumble at least one anyway. It would be really cool if you could find a place that could spray weld the walls with cast and bring new life back. Then it wouldn't be an issue of a sleeve loosening up or heat transfer as some think. This has been and is a fix for some that I have read about. It might be worth researching since some blocks may not be suitable for sleeving with thin casting walls especially if the block is a rare piece as 340's are deemed to be. Here's an idea that many will laugh at but if the block is an original and for numbers sake, the block could be sleeved and then install a custom set of smaller bore pistons or even go with an oversized set of 318 pistons. I doubt one would really notice that much difference in power. It's a shame a set of 360 pistons couldn't be use but then if you go with customs, they could if the pin bores were set at the right height. The 360 is only 0.040 under so using a set of 40 over would be right on. I knew a fellow in Waco that was often building engines using forging or casting blanks from one or another engine to make pistons ( in his shop ) to fit other engines, like a set of 454 Chevy piston fit into a Ford 390! .
That water pump bolt has an issue with SO many small blocks ! What a shame people haven't figured out to not do this is it doesn't go in all the way without resistance.
Every Top Fuel block has 8 sleeves. The Ford Cosworth DFV has 8 wet sleeves and spins to 10k faster than it took to type this. Find a good machine shop that has the right tools.
Those top fuel blocks are alloy which makes a bit of a difference and we all know they don't have a long life expectancy. The beauty is they can be welded back together lots of times. Cast iron is a bit harder to do.
I
i've got my 69 gts 340 done after the owner put to long of a bolt in the waterpump mounting , it cracked number 2 cylinder and the coolant filled the crankcase . no issues . saved my number matching car .
I want the truck you have in your Avatar to put my 5.9 Cummins in !
My 340 has two sleeves. I’ve been running this motor for 6 years without any problems.
can the 318 guys sleeve out a 318 block to make it a 340?
Why only sleeve it to 4 inch? If I was doing that, I'd go as big as I could, then stroke it !
But if the bore helps tie the deck to the lower end of the engine, on a production block, would it be wise to sleeve too many cylinders :rolleyes:
