Yes, with a thin cut off wheel.
And yes when large cuts are needed and cleanliness or accuracy is less important.
Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
It is. I was trying to be a little cheeky with my answer. “Yes and yes”. The torch (if oxy/acetylene) I would not use. It’s probably overkill for sheetmetal. Plasma yes though. And a cutoff wheel on a grinder is a definite yes.Is this a yes to both? I only have a cut off wheel and a torch, but Idk how to use the torch lol
@72bluNblu what do you use to cut the floor boards? Angle grinder? Plasma cutter?
