TKX vs T56
DentalDart
Ozark Missouri
Care to shed some light on why someone would choose 1 over the other?
Is one more comfortable to drive? Or more fun to drive?
If you start explaining gear ratio numbers I will not know or understand anything you’re saying so say it is stupid people terms like you have to shift out of first fast, your car loses power when shifting into last gear.
Photo for fun… 70 degrees and sunny in SW Missouri for Christmas.
T56 has better gearing and two over drives. But T56 is around 50 pounds heavier, a bit larger in size, and a bit more expensive. TKX is very good trans
I mean, beyond the extra gear?
The TKX still requires tunnel and crossmember work, but substantially less than the T56 needs. My rationale for the T56 was that if I was cutting and welding I was cutting and welding. I was comparing to a TKO though at the time because the TKX wasn’t a thing yet. While the TKX takes less modification it’s not like the car stays stock.
The T56 magnum (aftermarket version) is good for 700 ft/lbs of torque, so, 100 more than the TKX if that matters.
The T56 is also widely supported, I know there’s a couple different versions though and not everything interchanges. But some of the production models are pretty beefy and there’s a lot of support. The TKX is based off a T5 so there’s lots of production on the T5 as well, but the production T5’s aren’t that strong and I don’t know how useful any of the production parts are for the TKX. Either way if you’re not beating hard on the transmission the aftermarket support might not matter too much for either one.
With the T56 in my Duster I have the .80 and .63 overdrive gears. Even with that set up, 4.30’s and 27” tall tires I typically only get into 6th on the freeway. Most of the time I’d manage just fine with only a .8. But it is nice having the extra gear and I probably wouldn’t have gone to 4.30’s if I didn’t have the .63 as well.
I don’t understand the gearing. Most of my shifting will be up to 60 mph on side streets, not much freeway driving, maybe 10-15 minute freeway drives every couple of months.
The OD of the 56 I’ve read mixed reviews, people saying 6th isn’t usable unless going 70+ mph or on long drives?
There are two T56s one wide ratio and one close ratio. Then the torque curve of engine and rear gear ratio come into play. So 6'th isn't usable means the trans and rear gear aren't matched to the engine. So yeah if someone doesn't have a clue what they are doing when they built their car we can have cases where 6 is not usable.
Ok so say the engine is a 470 or 499…. 3.55 rear gears… idk if those are the best gears but it’s a set I was thinking…
5 speeds = really good acceleration from a dead stop to over 90+ MPH
6 speeds = really good acceleration from a dead stop to over 140+ MPH
6 speed is considerably bulkier requiring more tunnel modification....
Both are extremely fun....
This is perfect. I’m never going that fast lol
