stroked340
"Stroke It"..nothing like the feeling of a stroker under your right foot!!!
My 340 was fairly stock with a good cam, pocked work, good springs and push rods every thing else was stock. Oh and a little work on the oiling system, 3400 lb car 11.80 115 mph = about 410 hp at crank. With good port work, intake, better cam, and a good set of rods and pistons to hold it together I don' see a problem getting 500 hp. And it was street driven with no problem.
Lmao you hitting the pipe a little early?
That's why I try to keep a stock bore or as close as possible. I said before you finish the block first, only takeout what you have to. Then the bore is what it is, only then do you order the pistons.a local builder i know campaigned a '71 340 Duster that ran 11.5's consistently.He always said it was nothing special just a carefully assembled 340 with Edelbrock heads, a .280 duration cam and 10" slick.. never said what gears.
He tore the engine down in the off season,put a 3.58 stroke rotating assembly in it and changed nothing else.
It ran a best of 10.47 from then on shifting at 7800.Some time later he cracked a cylinder wall and that brings up the question of durability for a stock mopar block at 500 plus hp.
rumble, I saw a couple of videos on youtube saying that you get a lot of piston skirt wear with a stroker engine, so now I'm an expert, right?And of course this is a common happening and valid fear for stroker engines right?!![]()
Ummmmm, yea, OK, your an expert!!!!rumble, I saw a couple of videos on youtube saying that you get a lot of piston skirt wear with a stroker engine, so now I'm an expert, right?
