downsr
Getting ready to buy torsion bars any suggestions on what brand and size to buy.going in 70 duster 340 have 892 and 893 bars in it now one is damaged is why i am changing them
Must you realign after a torsion bar swap?
Here is a table for the OP of different t-bar sizes and applications:
http://www.hotrodreference.com/90/mopar-a-body-torsion-bar-size-and-part-number-reference/
Something else about torsion bars that crossed my mind recently... I don't know how much longer a B-body torsion bar is or if their hex ends are the same size as a-body but.. When fitting the A500 or A518 trans in a A-body, What if the entire torsion bar cross member could be moved rearward to achieve clearance ?
The ends of the T-bars are hexagonal shapes, that fit and lock into the chassis sockets and the lower control arm sockets. Looking from the end of the t-bars, these hexagonal shapes have to be in a certain orientation to each other on the front and rear ends of the bars to fit into the chassis right. There were some out there that were not made right and the design was 're-clocked' to get them right.So what in the heck does reclocking mean?
Stiff? It is all a matter of personal preference AND the application. T-Bars (and springs of any type) CAN be too stiff on roads that have rough surfaces and have large bumps; the shock/spring combo that matches will not be compliant on rough roads. That is why the OP needs to help with info. And the guys who like the 1" bars really would help to say what kind of roads they drive on and how, where they drive their cars, etc. ... IMO. It is like cams and compression raio : there are different characteristics and uses of different grinds; an HP cam won't typically be good for torque applications. And 11:1 CR may be great on the strip with the rigth fuels but would be unusable in general driving.
Living and driving in an around a large European city I can say I encounter all kinds of roadtypes, from brick stone roads, infested with speedbumps, upto smooth asphalt, also infested with speedbumps usually. And ofcourse the overabundance of roundabouts which seem so popular overhere.
Before I upgraded the Dart, coming up to most speedbumps made the car behave kinda 'ridiculous' if you didn't slow down enough; LCAs pretty much bottoming out on the upramp, suspension way unloading shortly after that, and the same happened in reverse on the downramp of the speedbump, followed by a few 'afterbumps' in the suspension.
In relation, newer cars don't really have to slow down.
Now, with the better torsionbars and shocks, I can drive over the speedbumps with the same speeds as all the other traffic around me, without causing unsettling suspension movements, making my car look like a cartooncar. (Well, not more than usual ;) )
On pretty much all road surfaces the car drives and handles much more 'serious' and modern than before.
If you look at the 1:19 mark in the Hotchkis videoclip below, you'll see exactly how my car also behaved after a dip/bump/speedbump;
Development of the New Hotchkis Tuned APS Adjustable Monotube Shocks - YouTube
My car now seems to behave pretty much just like the endresult in the clip.
