Tubular Lower Control Arm Thread
Here are the weights that I came up with using my trusty old bathroom scale. (May not be exact) Interesting if nothing else.
Torsion bar setup
340 torsion bar 7.2 lbs
Lower control arm 11.3 lbs
Strut Rod 3 lbs
Bump stop brackets (Cut Off) .5 lbs
Upper control arms 3.1 lbs
Shock 3.5 lbs
Total 28.6 x 2 = 57.2 lbs
Coilover Setup
Coilover with adapter 5 lbs
Spring 4 lbs
Tubular lower control arms 7 lbs
Tubular upper control arms 3 lbs (guess)
Aluminum strut rod (mine) 2.6 lbs
Total 21.6 x 2 = 43.2 lbs With 2 J bars and brackets 7.2 lbs x 2 = 14.4 lbs + 43.2 = 57.6 lbs
I don't care about unsprung weight, this is total weight.
So with the coilovers and extra bracing, which the front end on these cars need badly, you still come out the same weight.
i dont think i gain anything as i thought i would with a tubular frontend,as i think i went backwards,i had no problems with the stock stuff or header clearness problem,other than it looks cool,no gain
Ok I figured out what I want to do for the inner fender bracing. Option A is the J Bars that run inside of the engine bay. I have incorporated a landing on top of the spot welds on the factory shock tower. There is also an 1/8" piece of plate that will box the factory shock tower area for both options and should make that area considerably stronger.
Option A
Option A
Would this be instead of the one that connects directly to the shock tower from the J bar and has the holes cut in it like the one in the picture that was painted Red?
I believe so. This design is less complex and allows more clearance for guys running big blocks, plus it should be just about as strong if you ask me. The issue with connecting it directly to the shock tower is the amount of trimming to the inner fender that would have to be done to build a proper landing. If you look at where the shock attaches there is about 1/4" gap of air and that area would have to be removed. Where the plate in the picture attaches is a spot welded area that is a better attachment point if you ask me.
Just so everyone knows. I triple checked this measurement today on a 73 Dart Sport. With this coilover and adapter it puts it exactly factory ride height and possibly 1/2" lower. Should be a nice setup.
I can also make the adapters up to 3/4" shorter if you want a little more drop.
Wahoo Final mock up. Fits like a glove. I am using the factory upper bump stop. I am using Reilly Motor Sports Upper control arms and I have to say that the fit was spot on. I am impressed by the quality too.
I have decided to move the lower control arm coilover mounts out about another 3/4" to allow a little more clearance from the frame rail, but this setup works fine.
The Upper and lower arms will be sent out for powder coating this week also.
Do You not want to make both upper and lower control arms or is it a technical reason?
There are so many people making the uppers that I don't have much interest in it.
ah ok, was jw for price reasons, as I thought thats what everything being made was about! But I didnt know they were wide spread made, thought only Riley made them!
Do those arms have the factory "cant" of the ball joint built into them? Or are the tubes on the same horizontal plane as the ball joint itself?
I built them so after the main tube bend it is a straight shot into the ball joint, so yes they have the factory cant is built into them. Thanks for the question Curley.
I was referring to the UCA...are we talking about the same thing?
