I had hoped to be cranking my 440 in my cuda today. I purchased the 440 last year from this website. "Supposedly fully rebuilt," all new valve train etc. Heads were no good. Guides way out, seats were trashed, back of valves pitted severely. I tore it down and checked bearing clearances, .060 SP pistons, and checked good. Had been cut .010 and polished. Replaced the heads with stealth heads and after much cleaning up of old dried white grease used as assembly lube, I checked the new cam lobes and lifters for proper taper/crown etc. and all looked good. Degreed it in with a new timing set.
Long story short, after 3 gallons of anti-freeze and sitting overnight there is a leak somewhere on the left side. I haven't pinned it down, maybe a freeze plug? Who would rebuild a block and not change freeze plugs?
Earlier discussion with the member seller here about the **** heads resulted in "send it back"... After all the time and money spent, that wouldn't have been an option then. I would flame the seller here but it would serve no purpose.
So... today am going to start pulling parts back off and try to determine the leak location and pray I can fix it. Most likely will have to pull it out and re-plug all the holes.
Never again will I purchase an engine that does not have a bill of health and specifications from an actual machine shop. My gullibility I guess.
That's what I am doing to my Mopar today!!!
