I didn't work on my car today. Had a buddy pull his Impala into my shop for some help. My shop has a heated floor so it is a popular place in the winter.
Good Job.Finally got the fourth package with the last piece of nitrous hardware (converted my Powershot non-adjustable, super rich plate to a fully adjustable which I think they call a Super Powershot). So I put that on and set the (separate) regulator for 5.5 psi while feeding the .052 fuel jet.
Also removed both headlight assemblies completely, because they wouldn't aim high enough. The core support does not look bent or creased. The sheet metal brackets seem rather easily deformed, though. I slightly re-bent the lower legs on the brackets and reinstalled. Looks better but I'll have to wait for darkI bought the rolling shell completely (and I mean completely) disassembled. A literal basket case. So I don't know what exactly the hardware looked like from the factory. Are there supposed to be some kind of shims between the brackets and the core support?
I just pulled my 72 apart yesterday. Don’t know if these pics help but I don’t believe it’s ever been apart before. No shims. Just the four tabs holding the light on. And adjuster screw up topFinally got the fourth package with the last piece of nitrous hardware (converted my Powershot non-adjustable, super rich plate to a fully adjustable which I think they call a Super Powershot). So I put that on and set the (separate) regulator for 5.5 psi while feeding the .052 fuel jet.
There ya go. I’ll paint mine up before they go back on but the problem lies behind it. More rust. LolThanks - that's just what mine looks like (except I removed the rust and spray-painted them)Perhaps the front of the fender is bent at an angle - but everything bolted back up after painting. There are lots of variables too, such as front end ride height, rear spring height...
I may just add a couple of fender shims to the lower bolts if it's still off!
Go for it.i got about an hour to decide if i want to take the duster on a 1.5 hour road trip
its 35 right now, but gonna drop to 28
i dont have a heater, but its gonna be dry
Hammer on it!i got about an hour to decide if i want to take the duster on a 1.5 hour road trip
You live in Michigan. What were you thinking to delete the heater?i got about an hour to decide if i want to take the duster on a 1.5 hour road trip
Lol
You live in Michigan. What were you thinking to delete the heater?Lol
Wear a couple of layers and you'll be fine. If your near Roseville? Stop and warm up. I have a heater in the garage & Whiskey.
Wear a couple of layers and you'll be fine. If your near Roseville? Stop and warm up. I have a heater in the garage & Whiskey.![]()
Nope. Not at this stage of the build.Apparently you won't be working on the car later...
