TONYMOPAR
are there any road tests or dealership pictures or list of what items the 383 package included?
balls
You said balls.
balls
You said balls. Again.
Should I have said odd "Ball"! Certainly I do not have the only 69 with the lack of the heater hose mount hole!You said balls. Again.
Ball
Yes odd "balls". My 69 with good proof, never had the hole drilled in the normal location for the heater hose bracket.
Mine has the screw hole & the bracket on the inner fender for the hose bracket & also the right valve cover has the hose bracket. Not sure why bothIt is in the factory information available thanks to alaskan_tr
on The 1970 Hamtramck Registry Home Page
What is not clear is odd balls like mine that never had a screw hole for the heater hoses on The inner fender!
What's your angle Tony?
Yes, yes I did LMAOCawley said "screw hole"
