Every day ? There is a problem somewhere. I would try a different car or different mechanic.
I am the mechanic, for the most part. The car is 100% mechanically sound after 2.5 years of working on it. Now I have stripped her down and am doing body work.
Being disabled, I can only work 2-3 hours a day. Many, many breaks and rest periods.
In June it will be 3 years I have been working on it. Slow but sure wins the race.
Plus on top of the car I have other projects.
In the last few weeks, I :
1. Ground down the stumps from the two palm trees, to below ground level
2. Planted two new palm trees and put a retaining wall around them. (The two new trees are descendants of the two palms I removed)
3. Retrofitted the electric tank-less water heater with a new flow switch, because the factory one was not turning on the heater.
4. Built a circuit to switch and installed annunciator LEDs so we can see the water heater is working without going into the garage.
5. Fell thru the ceiling in the garage, (when the old floor boards broke) while finishing up #5 above. Did some major damage to the left leg.
6. Removed and replaced the floor in the attic
7. Repaired the ceiling in the garage
8. Bought, repaired a new electrical generator (large enough to power at least 2 homes during an outage) Then installed an interface into the electrical panel to hook it up to the house
This is why it takes so long and I need 365 days a year of tolerable weather
