Which 727 Transmission fluid type to use?
nitronut
I'm topping off my 727 auto transmission fluid level and not sure which trans fluid to use. The transmission has been rebuilt with a shift kit. Fluid level's a little low and want to use some good fluid recommended for the Mopar. Any suggestions? Thanks in advance...
Type F is what we always ran back in the day. Now I just run the universal stuff they sell at the parts store.
The best advice I can give you is run a deep pan. Best bang for the buck for keeping a torquflite alive.
All Mopars are now retro fitted to run ATF+4 ,
Highly friction modified fluid for all Mopar 3 & 4 speed automatic applications
Lon
I personally use type F, but the TF's do not care if you run F, Dexron, or the expensive ATF+4. Run what you want!
Any brand of Dexron Mercron “multi-vehicle” will be all you need.
It’s honestly not as critical or complicated as one might think. Run at the proper level and using a cooler is what really would matter
what ever the latest dextron is that is compatible with dextron III
