from post 59
"So correct me if im wrong. Im going to set the timing a bit higher into the 20 range for initial and then see what the total is. If its too higj or too low the dist needs changed to get the desired total time?"
yes and no
You are going to reset the T-port first, and defeat the vacuum advance(note4). Then you will twist the dizzy up to some undetermined number LIKE in the range of 14* to 22*, so it will stay running during the warm-up period;and then hit the starter. After the engine has warmed up, you will set the idle speed with idle air bypass(note1) and timing.(note2)You will not touch the idle speed screw again.(note3)
-Note1)Idle air bypass is simply air that you introduce into the engine almost anywhere, EXCEPT through the primary butterflies. This will be a controlled vacuum leak. The most common place to let air in is through the secondaries via the cracking screw. The PCV is another. Certain carbs have a built-in idle-air bypass screw.There are also other ways.
-Note2) It may end up that 20* is perfect. But to to arbitrarily choose 20*, is to invite futzing with the speed screw again! After the idle timing is determined, then the power-timing may have to be limited, and the rate of advance dialed in.
-Note3)if you cannot get a stable, smooth idle, with the above system, and with the idle mixture screws in, near the center of their normal range, then it is permissible to add or subtract a little transfer fuel.It may be that the arbitrary sync that you initially chose, was not quite spot on. But don't stray far from the initial setting. Of course if you do futz with the speed screw, you get to re-start the bypass air adjustment.
-Note4) at some future date, after you have the mechanical timings(plural) sorted, THEN you can re-introduce the V-can.
You need to give this process more consideration. This is not a slam it in and done deal. If you move ahead too fast, you are inviting endless driveability issues that will make commuting less than pleasurable. Probably something like 70 or 80 or more percent of the driving experience will be on this tune.
ALL streeters should have a well tuned vacuum advance system.It adds so much.The oem distributor would have to be really worn out to consider replacing it.There is a guy on FABO that makes timing limiter plates. I think that was already mentioned in this thread.
