just one more cam selection thread
@PRH For shame on you!
Don’t you know you ya e up at least 70hp by not using an inverse high lift solid cam! LMAO!
I can’t believe you! LMAO!
(Yes!! Mega sarcasm!)
The fact is, most(all? I didn’t really scrutinize them all) of the cams recommended in this thread would work fine.
I have only used the Crane 272 and 278 cams a few times, and I liked other grinds better...... so didn’t go back to the Cranes.
They worked well enough, but I felt there was a little “something” left on the table(no back to back testing at all though).
I’m not usually in the “12 extra degrees of exhaust duration” camp with Mopar stuff........ and rarely go for the 112-114lsa unless it’s for something specific, that doesn’t pertain to making more power.
My Dad used to have a 77 B200 3/4 ton conversion van....... the medium length size. Came with a 318-2bbl.
We installed a re-ringed mid-70’s 360, 1.88 360 heads, std Performer, Holley 600vs, headers.
Ran the stock converter(used a weighted flex plate), 3.23 gears, L60/15 rear tires.
Towed a 3700lb 79 Córdoba on a 1300lb open trailer all around the hills in New England to various drag strips for years. Plenty of power.
Oh yeh...... used a pointy nose Comp 268H in it.
One day at the track there was some issue with the car that was discovered before the first time run was even made.
I don’t recall what it was, but the car wasn’t getting raced that day.
Unhooks the trailer from the van, ran it in the street class.
Went 15.60’s.
That's hardcore when you end up running the tow rig.
Poor flowing small valves stock heads get the big split. That’s it.
Hi there I asked how to choose a cam for a lo comp 360 ended up with a Racer Brown cam EH-71 262 , .450 lift ,214 intake 105,exhaust 111,lobe separation 108. Intake open 2.0 BTC. Close 32.0 ABC
Exhaust open 38.0. Close -4.0. ATC
Spring pres. Seat 115+. Open 270-280
Lots of torque and surprising good gas mileage very happy with it and not bad price my 2 cents forgot to add single pattern he said do not want more duration on exhaust I don’t have enough compression or high enough rpms to use more if I did more exhaust it would hurt your torque,this is a mopar lobe so fast open and a little slower on the close he did offer one other cam 220 with .450 lift and lad of 110 but with some drivability issues the one I got he said would be more of seat of the pants power .
Sounds like another good choice.
I must be ok. I still have a full head of hair. The barber gets out the thinning shears and I tell her no! LOL Now the sanity part. Maybe not! Nothing wrong being a little crazy! LOL
I preach on it a lot but I think here it will be a great fit. The Crane "magic" cam.
Crane Hydraulic Flat Tappet Camshafts 693801
This is an effective choice, but I'm not wild about the wide LSA for the OP's application. I have personally run the MoPar Purple 260/268 .430/.450" 110LSA in a 360 and LOVED it (don't believe the published .050" duration figures, either!). A cheaper single-pattern alternative is the old Cam Dynamics "Energizer" 272, still sold my Crane and also available "white box" from Summit. 272*/216*/.454"/110LSA. Used in a 318 it's fairly rowdy, a 360 should love it. My .02c worth.
216@.050 LMAO
But yeah, that's a good one. Isn't that the one in your grey truck?
Poor red and white. I miss that truck. :(
Remember that BTK-like guy we got the MONACHO from? We took R&W up there on the hottest day in modern history and it got the job done while keeping us cool! I think we drove UP Moneagle with the empty trailer!! LOL. I still haven't torn that dead 360 down..
It was Blood Mountain we went up I thought. But yeah, "whichever" it was we both agreed "we ain't going "back down" loaded. lol
...and that guy......he was a pedophile if the highest degree. I bet he had cages of starvin kids around there somewhere.
