MopaR&D
Nerd Member
I'm running a Summit billet distributor in my 360 (hooked up to a 2007-vintage Mallory HyFire-6A box) and I'm wondering if I might get a little more bottom-end grunt if I have the mechanical advance come in faster. It's a 5.9L Magnum short block with ported Edelbrocks and a custom-grind cam 222/226* at .050" on a 110 LSA. It's only 9:1 compression with the stock Magnum pistons and while the low-end torque is ample, I've found this engine is also very detonation-resistant; it runs on regular gas and I've found max power total ignition advance to be around 44 degrees BTDC (yes I know that seems very high but I have the "open chamber" Edelbrocks and I'm at 5000' elevation). Any more advance and it starts to ping slightly, any less and it doesn't pull as hard in the higher revs.
Anyway my current driveline setup is a 904 with a cheap 2600-stall converter and 2.94 gears in the 8 3/4" rear; I have a 3.55 ring and pinion and will be changing to those gears in the near future but it would be nice to get a little extra grunt with the tall gears for now, if possible. Currently there's 20 degrees of mechanical advance (so 24 initial, 44 total) that is all in by 2200 RPM. Could there be any gains by having it come in earlier or does that seem about as good as it'll get?
