yellow rose
Overnight Sensation
Depends on the shock.
The way Calvert explained to me years ago was that the adjustment on the shocks is for the rebound but also makes small changes to compression. My Dart with the 408 went a bunch of 1.38 60' with them and CE three ways on the front so they can work but there isn't much adjustments for poor tracks.
See, that’s what they told me...turning the knob changed the rebound and the bump a small amount. How much that was and if it changed with the setting (as in if you are at one end of the settings does the bump change the same amount at the other end of the setting) they couldn’t say.
It’s confusing for sure.
