Thou art kicking ath lolFinally got all of the under hood, dash and rear half of the car wiring done. Only thing left to do is eliminate 75% of the main harness and wire up the lights up front and I’m done with the electrical. I might stay home tomorrow and finish it up so this weekend will be topping off coolant and trans fluid, then running the engine up to temp and setting timing. That would have been enough to take it for a drive except I decided to order another spooled dropout with 4.30 gears and gun drilled 40 spline axles so the rear ended is apart. Maybe I’ll get lucky and the new parts will show up tomorrow…. lol
