~450hp from stock stroke 340?
Aluminum heads are absorbing compression because they’re a heat sink. If your static is 10.5:1 your cam choice should be in the 9.5-10:1 range.
In theory but in practice I don't believe there's a power difference between the two but yes seems you can squeeze a bit more cr from aluminum heads and run on pump gas probably less chance of hot spots.
The crate motors made power because the came equipped with cast iron heads flowing 25 more cfm than the J head untouched.
I don't know about 25 cfm more, Charles Servedio flowed both and are fairly close to each other on intake side, J had slightly more peak flow and magnum had slightly more low flow, exhaust magnum did a lot better, probably that and more do to port and chamber shape for hp gain.
i have a client with a 67 RS Z28 302/4spd, which i understand is crazy rare. it's a super time capsule and a really cool car. total day two with keystone kustomags, lake wood slappers and hooker's. i don't know if it came with 4.11's or the PO did them along with the other stuff, but it was a serious piece. the guy had me swap in some 3.55's so he could drive it and enjoy it a little more.
but to your point, that thing loves some gear. so much fun to twist its tail and just let it sing.
There was a guy in LA way back that had a 69 Z28. Ran around with 5.38's in it. Launching that car was fun to hear. Screaming little SB.
Aluminum heads are absorbing compression because they’re a heat sink. If your static is 10.5:1 your cam choice should be in the 9.5-10:1 range. The crate motors made power because the came equipped with cast iron heads flowing 25 more cfm than the J head untouched
Not again.
I think every engine builder has his or her thoughts on this subject. I know I have mine and will keep them in the vault
They can think what they want. But publicly posting error keeps people in the dark.
Aluminum heads don’t suck power. They don’t reduce detonation.
But that myth will keep going because it hasn’t been eradicated yet. Probably never will.
might still be down here running around!
a lot of cars from back in the day are resurfacing as the former owners are checking out, have moved on or their kids are now dragging them out to get 'em going again.
i find great joy in putting something back on the street that's been dormant for ages-- even if it's *slightly* de-tuned from what it was back then; they're still cool cars and it's great to see them out running around.
Newbomb,
Thank you for enlightening me:
My comments were not intended to be misleading, they come from following Larry Shepard's Book. On my budget I follow his recommended cylinder head compression ratio combinations.
Swapping the Speedmaster 2.02 aluminum heads for (New Zealand) EQ 318B 1.92 on my La 360 short block netted me a lower et and better mph with flat top piston combo. The swap included a cam change as well, from the 238/238 108 solid to a 248/256 110 assuming the cylinder pressure went down about 10psi with the EQ's.
Newbomb,
Interesting.
Newbomb,
You went a lot bigger in cam so definitely the power output got higher. Not sure id attribute the gain to the heads.
Especially something that was well known and revered. That's just cool stuff. Years ago when I was alignment guy at a local tire shop, we had a guy come in askin if any of us was interested in helping him revive an old "muscle car" and he wasn't a mechanic and didn't know much about it. I agreed to go look. We get over there and here's a 1970 Torino Cobra with a 429 CJ and 4 speed. I knew the car from years back. It was a holy terror on the street. It wouldda been fun to do, but I looked it over and it had mega rust in the back. He decided to sell it.
Exactly. The 500 HP 327 chevy from 1980 is still the king, even though a 500 HP anything back then was impressive. And very few of those were even 400 HP.
I can do 450 on 340 inches. In fact, I'm probably going to go over 500. And that's with some shitty parts.
Most guys wouldn't want to drive it because they will already have in their mind its too radical to be drivable.
@lead69 I think ran my engine through one of his engine programs and it was 540 HP or something.
I doubt it will get there. 500 is more than I originally started out shooting for. I want a nice, clean 11.60 car. At this point I probably overshot that ET by a little.
How much of the short stroke V8 hp potential is determined by effective windage control.
Well, I suppose I can test that on my engine if I really want to know but it’s a giant PITA to change the pan on the dyno and add the crank scraper and get it sealed.
The scraper makes it so you don’t use any gaskets so that’s a PITA all its own.
I’ll think about doing the testing though.
This I do know. My oil pressure on the exact same engine with the exact same parts except adding the scraper made my idle pressure go up by 10 pounds both hot and cold.
I use an up and down scraper, plus a windage tray.
When you mentioned the 500 HP 327 I couldn't help but think of Grumpy's discussion about oil winding itself around the rotating assembly. I fabricated a perforated windage tray for my 340 in a effort t see any improvement in oil scavenging, but I haven't needed to swap out a motor yet. Who makes the scrapers for your application.
Ishahra-Johnson makes the scraper I use. It is the one with Teflon that self clearances. If I get in the shop today I’ll take a couple of pictures of both and post them here.
When you mentioned the 500 HP 327 I couldn't help but think of Grumpy's discussion about oil winding itself around the rotating assembly. I fabricated a perforated windage tray for my 340 in an effort t see any improvement in oil scavenging, but I haven't needed to swap out a motor yet. Who makes the scrapers for your application.
This is an I-J up and down crank scraper with the self fitting teflon insert.
