I've changed cams in the 422 stroker small block in my Arrow. The cam that was previously in the car was a Bullet grind with the following specs:
Gross lift: Intake .685 Exhaust .682
Duration @ .050 Intake 276 Exhaust 285
LSA 106 Installed 4 degree retard
valve lash hot .026 / .026, set .018 / .020 cold
Current cam is a Comp Cam with the following specs:
Gross valve lift: Intake .659 Exhaust .662
Duration @ .050 Intake 275 Exhaust 284
LSA 108 Installed straight up on the advice of Comp Cams Tech Department.
Valve lash listed on cam card .026 / .028 which I assume is hot, card doesn't specify, set .019 / .021 cold
engine specs are 340 X block 4.10 bore, 4.00 stroke, 13.0 - 1 compression, W5 CNC ported heads, Holley Pro Dominator tunnel ram with dual 850 Venom carbs massaged by Dominic Thumper. Powerglide with 5500 converter, 4.30 rear gear.
The engine builder and previous owner of the car told me he never liked the Bullet cam and has told me this Comp Cam should perform better. My best ET/MPH with the Bullet was 9.12 @ 146 in the 1/4.
My question is what performance can I expect with this cam change. I know there are other variables that will affect performance so I'm asking in general terms what I might expect. I'm worried that I've shot myself in the foot with this change.
Also, with these aluminum W5 heads what would be a good cold lash setting for the Comp Cam?
Should also add that these are both mechanical roller cams with Harlan Sharp 1.5 roller rockers.
