I have a bunch of general tools and access to an engine lift, would this be an insane job to do myself?( replacing the k that is?) Looks like ill meet up with the dude with the k at 10 tomorrow. I remember looking at an article in mopar magazine a while back about doing this job
I get the impression you are young and in good shape? I recently swapped one into mine I'm 66 and have osteo and arthritic problems. A hoist makes it easy. I padded the inner fenders, used a big 4x4 blocked up with blocks and a chain to support the engine. Here:
I think I already posted the link once...........
http://www.forabodiesonly.com/mopar/showthread.php?t=227050
You can do this a bunch of ways. HERE IS what I would do and why...........
Break loose your spindles and ball joints, and calipers, etc and remove them. YOU SHOULD CONSIDER swapping the calipers and spindles to the opposite sides of the car. This will put your calipers on the REAR of the spindles instead of the front. This is for increased clearance for a sway bar if you should install one (Some aftermarket ones won't clear front mount calipers)
On the sway bar subject, your spool mount (anti) sway bar must be the proper one, as it threads through the INSIDE of the K member, unlike the earlier version.
So break the upper balls loose and remove the spindles, calipers, and if you are going to replace them, the ball joints.
Then remove the T bars. READ the shop manuals
There are two clips in the rear of the bars. You can remove the strut rod nuts, and the LCA pivot nuts, and pry between the LCA and the K member, and force the LCA and the T bar towards the rear, then slide out the T bar
You'll re-use the center link and idler, but you can strip them on the ground about as easy. Depends on whether you need to lighten it to handle it. I used bike tie downs to lower the thing
When I put it back in, I just blocked it up on concrete and blocks, and lowered the lift to meet it.
