AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,617
- Reaction score
- 13,853
Hang on WAj that must have been an ENGLE they use .008 which is close to what MP would be if they measured duration by lifter rise- but they don't
they take it off the blueprint starting where there clearance ramp meets the acceleration ramp
The stock 440 magnum cam is like 310 SAE (004)
toolguy Comp Cams and Isky are not exactly cheap and certainly not a good value in a Mopar XE-HL exceptred to bad they do not make a complete line
and no one in their right mind would custom grind of the lobe list
I came to the same conclusion about it being an Engle.
As for the rest I'm gonna need an interpreter,lol.
Here's all I got since I did not degree the advertised to verify.
I have had the 2430 and currently in the engine is the 3038
Across the top, column 5; it says "at .008 lift". We might need an interpreter for that too,lol.
#6---Older Camshaft Profiles (Small Block Hydraulic: HE Series)
